Author Topic: c-notch frame and narror rearend 74 2wd sb  (Read 5553 times)
Offline 572 NITRO
« on: February 06, 2005, 12:45:00 pm »
How low can you go before you have to c-notch the frame on a 1974 c 10 sortbed 2wd? Also does anyone know what narrorer rearend will fit under these trucks? My friend put a ford 9" under his that was 2" narrorer. Would like to stay with chevy.
Offline Sano
Re: c-notch frame and narror rearend 74 2wd sb
« Reply #1 on: February 06, 2005, 12:02:00 pm »
I believe you can go about 5 inches before you have to c-notch the frame. And as for a narrowed rear end, people do it all the time so yes the do fit, and I really hate to say it but the ford 9" is one of the best rear ends you can have.
Offline roundedline
« Reply #2 on: February 07, 2005, 06:06:00 pm »
9" is more popular because of its steel housing.  Easier to weld on, plus you can bench setup the gearset.
In reality a 12bolt is just as strong and uses let power to operate by design.  Downfall is you can weld confidently to the center section.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
