Author Topic: MY 84' C10 LWB WITH 20'' TAHOE RIMS.  (Read 14420 times)
Offline figure843
« on: June 30, 2012, 10:32:45 pm »
This is my 84' C10. I took the wheels of the my Tahoe and mocked them up to my truck to see how they would look. I'm not to sure about it. I know that I would need adapters. I would like some input from you guys. Thanks!   ;D
« Last Edit: July 01, 2012, 12:42:12 am by figure843 »
1984 SILVERADO LWB 350/400
1988 SILVERADO K5 BLAZER 350/700R4/NP208/3:73/6"RC LIFT/38.5/15/15 BOGGERS
Re: MY 84' C10 LWB WITH 20'' TAHOE RIMS.
« Reply #1 on: July 02, 2012, 07:32:51 am »
     I don't think they would look that bad as long as you evened up the front and rear tire to wheel well height.  The front has more of a space and it is making it look funny.  I do not know if it is the way the truck is siting or not, just does not look right.
Offline slammed79
  • Thou shalt not drive stock
« Reply #2 on: July 02, 2012, 09:58:49 am »
They don't look bad. Just be careful with adaptors, they could push the wheels out of the wheel well
Praise the lowered
Offline figure843
« Reply #3 on: July 02, 2012, 04:18:09 pm »
The truck is on jackstands. That is why it is sitting like that. I should of took the time to level it right. It still gave me a general idea what it will look like. Thanks.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #4 on: July 29, 2012, 09:42:25 am »
I like em.  looks good to me.
Offline got2haul
« Reply #5 on: July 30, 2012, 09:38:20 am »
Your post states that your truck is a C10.  C10's have 5-lug wheels, correct?  I know you already know this, since you state that you'll need adapters -- the Tahoe wheels you're talking about using are 6-lug.  I went through this a while back looking for adapters to go from 5-lug to 6-lug and was unable to find ANY that would adapt a wheel that has a 6x5.5" bolt pattern like your Tahoe wheels to a 5x5" hub like the C10.  I called several companies that I found online that make adapters, and they told me the bolt pattern measurements were too close together to be able to drill the 6-lug pattern correctly.
Don't get discouraged, though.  You might have better luck than I did in locating proper adapters.
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Offline figure843
« Reply #6 on: July 30, 2012, 03:19:18 pm »
I had found the adapters. But after doing more research i realized that that adapter has to share one of the same holes so it would have to be a 2 piece adapter. I don't plan on doing this any time soon. But when i do I would probably just change axles and rotors. Much safer too! Thanks for the input.
