Author Topic: Temp gauge sending unit  (Read 3800 times)
Offline 454Man
  • Why Race?
« on: July 02, 2012, 08:06:06 am »
My current temp sending unit has a separate bolt that sits on top of it and compresses the lip of the sending unit to create a seal. Well I am no longer able to use the t stat housing and all the other locations won't work because they are too deep. Are there any aftermarket temp gauge assemblies that don't use the slip collar bolt on the sending unit and are just one peice? Help is needed on this thanks guys!
Offline Fairlane514
Re: Temp gauge sending unit
« Reply #1 on: July 02, 2012, 08:27:51 am »
You will have to use a sending unit that operates on the correct ohms for your particular gauge.  Switching to a different style without the correct ohms will not allow it to read properly.
Offline 454Man
  • Why Race?
« Reply #2 on: July 02, 2012, 09:25:48 am »
Well I am in the market for a new setup. The mech one I have is not a detachable peice from the gauge. So I may have to go electric. Guess my question is what brand has o one peice sending unit
« Last Edit: July 02, 2012, 09:27:39 am by 454Man »
« Reply #3 on: July 02, 2012, 01:10:58 pm »
Aftermarket or?  If you want your factory gauge to work, it would have to be a comparable sending unit...
Offline 454Man
  • Why Race?
« Reply #4 on: July 02, 2012, 01:32:08 pm »
Aftermarket. I'm open to suggestions
