Author Topic: 89 - 91 'Burban/Blazer Mirrors Switch and wiring harness info  (Read 5768 times)
Offline scorpion
Just got learned on the third style of side mirrors for the 73-87 trucks and forums and found they're available on eBay in either Doorman or import knock-off (so I can get 'em I'm sayin').
1.  Does anyone know the doorman part # for the controller switch?
2.  Is the harness complicated (the mirror plug appears to have about 5 wires or so)?
3.  Does anyone have pics of the braces that are used with these mirrors?
I've searched and there's not a ton of info out there.  Maybe most don't like them even though they appear to look more modern.
Thanks.
Offline fitz
Re: 89 - 91 'Burban/Blazer Mirrors Switch and wiring harness info
« Reply #1 on: July 04, 2012, 05:53:52 pm »
Best bet is to find a parts truck and grab it all.
Might as well grab the switch off the same truck you get the harness from.
I'll try to get some pics of the harness over the weekend.
Offline fitz
« Reply #2 on: July 04, 2012, 05:59:49 pm »
Mirrors plug in just like the windows & locks.
Offline scorpion
« Reply #3 on: July 04, 2012, 09:53:58 pm »
Sweet, that helps a lot.  Thanks!
« Reply #4 on: July 07, 2012, 11:03:57 pm »
http://forum.73-87chevytrucks.com/smforum/index.php/topic,18539.msg148078.html#msg148078
BTW, the mirror head itself is the same the 91-up electric mirrors for the C/K trucks and the Astro Vans.  Mounting plate is going to be the hard thing to find.
Offline scorpion
« Reply #5 on: July 10, 2012, 04:34:22 am »
That's good info.  I should be able to find switches and wires that will work.  I could make the brackets if I had a pair to look at...isn't that always the case?  LOL
If anyone finds pics of the brackets, it sounds like that's going to be my challenge.  Worse case I could try to make my own set (they probably just brace the outer door skin to the inner somehow).  If I can find all of the pieces I might give it a shot.
