Author Topic: 86 k10 vacuum crap  (Read 4063 times)
Offline hotrod24
86 k10 vacuum crap
« on: July 09, 2012, 06:49:36 pm »
Ok me and my dad started taking all the crap off his 350 and we got most of it all off but the hoes that screws in the manifold it want come out... please help
1978 pontiac grand prix...
Re: 86 k10 vacuum crap
« Reply #1 on: July 09, 2012, 08:36:43 pm »
     I assume the hose is attached to a threaded piece that screws into the manifold.  As long as it is screwed on and won't come off, I usually heat is up, then use "freeze off" to "un-weld" the piece, has worked every time for me.
Offline jaredts
« Reply #2 on: July 10, 2012, 04:55:06 pm »
Where are you talking about?  The only thing I can think of that screws into the manifold is behind the carburetor and you'll probably want to keep that for your hvac, cruise and trans. modulator if you have them.
« Reply #3 on: July 10, 2012, 09:08:10 pm »
If you are talking about the air tubes on the exhaust manifolds, get the nuts red hot with a torch or better yet invest in a set of quality headers.
