Author Topic: 86 Chevy Cummins crew cab build  (Read 11850 times)
Offline 84 chevy guy id
« on: July 11, 2012, 02:21:45 pm »
I been collecting parts for awhile and finally got started on this huge project. I started with an 86 chevy 2 wheel drive crew cab long box and a 94 ford school bus. I looked around for awhile to come up with a truck with the options and the right colors, this one was a 10 hour round trip away and was just the body with no engine or trans, which saved me some work. I picked up a pair of 90 dodge axles with 3.54 gearing and have a 4l80e and a driver drop 241 tcase. I am using the "52" inch chevy springs for the front suspension and built front spring hangers for them, just picked up the rear hangers and shackles last night. I have the 4x4 rear spring brackets and got the front brackets installed the other day but havent changed the rears yet as I am comtemplating doing a shackle flip and maybe I wont have to swap brackets.
I pulled the motor out of the bus last week and got the 545 trans and adapter removed. I want to have some sort of air ride/assist on the suspension so I want to leave the air compressor on the motor but that sorta rules out using any side mount motor mounts. Since I have the front mount already on the motor, I was thinking about doing bellhousing brackets like the bus setup was, also doing a trans/tcase mount too. Here are a few pics.
87 Suburban 6.5 Banks turbo 700/208
87 Blazer 350 700/208
86 Crew Cab soon to be 5.9 4L80E/241
84 Std Cab 400 465/208
72 Vette 468 twin turbo 4L80E
Re: 86 Chevy Cummins crew cab build
« Reply #1 on: July 11, 2012, 07:01:38 pm »
     Well it is interesting to say the least, I will be following this build.  Keep up updated on your progress.
Offline cubicdollars
« Reply #2 on: July 13, 2012, 09:24:46 am »
Good Luck with your build !! you will absoutly love the swap.
Offline Edahall
« Reply #3 on: July 14, 2012, 11:24:23 pm »
Subscribed
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline mikek20
« Reply #4 on: July 14, 2012, 11:27:26 pm »
You have my undivided attention on this one. Good luck
Offline slammed79
  • Thou shalt not drive stock
« Reply #5 on: July 14, 2012, 11:28:00 pm »
I'm in. Lemme go get some popcorn.
Praise the lowered
Offline big bear
« Reply #6 on: July 15, 2012, 08:10:22 pm »
 killer project...im with these guys,im subscribed
Offline BigHemi353
  • Diesel Enthusiast
« Reply #7 on: July 17, 2012, 02:38:29 pm »
Nice project! I wish I went with a crewcab when I started my cummins swap but I'm kinda stuck with the standard cab now. Looking forward to seeing your progress!
Offline bigchevyc30
  • the pig
« Reply #8 on: July 17, 2012, 09:37:44 pm »
thats a big ole cummins there cant wait to see what you do after we get moved ill be doing pretty much the same thing but hopefully with a dually and possibly a smaller motor than the one you have
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
