Author Topic: Clutch resivior hose...what should I use???  (Read 7487 times)
Offline thefarmboy21
« on: July 12, 2012, 03:08:14 pm »
My 86 has a hydraulic clutch and it needs a new master cylinder because it is leaking. The hose that runs from the resivior to the master cylinder is just a black rubber hose but it is severely dry cracked and I don't even know how it's holding up. So, what kind of hose do I replace it with? Ex co-workers from AZ said just regular fuel line will be fine. Anyone have any experience with this???
AMSOIL DEALER # 5583011
86 Chevy K20 Custom Deluxe-Grandpa bought it new 11/20/85
77 Chevy K10 Custom Deluxe-Dad's first truck
69 Chevy C30 flatbed-Grandpa's farm truck
1950 International L-112-Grandpa bought it new, parked in 1963
Offline slammed79
  • Thou shalt not drive stock
Praise the lowered
Re: Clutch resivior hose...what should I use???
« Reply #2 on: July 12, 2012, 04:29:47 pm »
Fuel hose isn't rated fore hydraulic pressure.
Here is what you need
 http://www.autozone.com/autozone/parts/Brakeware-Clutch-Hydraulic-Hose/1986-Chevrolet-C10-1-2-ton-P-U-2WD/_/N-ij11lZ6o3a9?itemIdentifier=976160_0_0_
From the reservoir to the master is not under pressure.  I've wondered the same thing as both my hoses described in the title on my 85 and 86 are cracked badly.
Offline thirsty
    • Suitor's Garage
« Reply #3 on: July 12, 2012, 06:26:53 pm »
I have regular fuel line on mine. It's been there a while and seems to be holding up fine. I just looked at it to make sure before I posted this. It may not be the correct type of line but it works.
« Reply #4 on: July 13, 2012, 09:23:57 am »
Yea it has no pressure at all. All it's there for is to transfer the brake fluid. I just want to make sure the brake fluid won't eat the regular gas line. I thought maybe I would need vinyl or power steering hose etc...
Offline slammed79
« Reply #5 on: July 14, 2012, 03:48:57 pm »
Should if paid a little more attention, my bad.
Praise the lowered
