Author Topic: cutting coils  (Read 5427 times)
Offline Spongebob
cutting coils
« on: March 02, 2005, 10:42:00 pm »
I want to drop the front end (77gmc) 2 inchs.  If I cut one coil each off my springs would it really ride that much rougher?  Does anyone know if one coil would drop it 2 inchs or would it be too much or not enough?
Thanks
Offline roundedline
Re: cutting coils
« Reply #1 on: March 03, 2005, 04:45:00 pm »
Being the coils are relatively old, there is no way to accurately state how much cutting off the coil will yeild 2" drop.  TYPICALLY 1/2 should be a good starting point.  If you have no experience in doing this, I wouldn't recommend it.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline Spongebob
Re: cutting coils
« Reply #2 on: March 04, 2005, 12:29:00 pm »
Already done.  Took it apart, cut off half and put it back together.  This gave me .5 inch drop, not enough.  Took it apart again and cut off another half.  Back together and it gave me another inch drop for a total of 1.5.  That's good enough for me.  Incidentally I cut from the bottom of the coil and used a metal cutting band-saw.  Looks great and the ride never noticeably changed either.  Wouldn't want to cut anymore off though.
Offline roundedline
Re: cutting coils
« Reply #3 on: March 07, 2005, 10:04:00 am »
You did it the correct way.  I wouldn't try for more than 2" the ride will suffer.
Project Su
Jimmy 2WD Project
