Author Topic: Frame paint  (Read 9752 times)
Offline Chevy Truck Guy 86
Frame paint
« on: July 19, 2012, 02:51:28 pm »
I know very little about painting. I am trying to figure out how to paint my frame, should I put expoxy primer on bare  metal, then primer on top of that and then black paint? or is there something else I should know. How should I do this?
If there was no rust when you restore a vehicle, it would be to easy.
Re: Frame paint
« Reply #1 on: July 21, 2012, 01:35:08 am »
Has it still got factory paint on it?
Does if have rusty areas?
Did you sand blast it?
If it has original paint and rusty spots, I would sand blast it and start over with A self etching primer, then paint.
Or sand the old paint and needle scale the rusty section. then use Chassis Saver over the rust, then paint it with an in expensive Acrylic Enamal equipment paint.
Re: Frame paint
« Reply #2 on: July 21, 2012, 08:26:35 am »
So if I were to use something like this! Couldni put this on, then top coat it right away, I've read online that self etching primer needs primer on top of it? http://www.eastwood.com/ew-self-etch-primer-quart-gray.html?utm_content=16009%20ZP&utm_campaign=GoogleSean02&utm_source=Google&utm_medium=Merchant-Centre&SRCCODE=1SE0756
Re: Frame paint
« Reply #3 on: July 21, 2012, 06:39:14 pm »
Self etching primer is for clean bare metal only. It does no good over rust, or paint. I needle scale and pressure wash frames, then scuff up the old paint that's still adhered well. Chassis Saver the surface rust, then spray the entire thing with an inexpensive equipment acrylic enamel. Done.
When i use self etching primer I spray right over it with paint or SEM bed liner all the time. No problems.
Offline jaredts
Re: Frame paint
« Reply #4 on: July 21, 2012, 08:33:43 pm »
All of the self etching primer cans I have read have said that they need a sealer over them.  I'm not sure why though???
Offline 81GMCBILL
Re: Frame paint
« Reply #5 on: August 16, 2012, 09:56:42 pm »
Blazin : what do you mean by " needle scale" ?  Is this some type of process of removing rust ?
85 GMC K25 4X4 383/th400/np208
Offline bake315
Re: Frame paint
« Reply #6 on: August 17, 2012, 01:28:25 pm »
Here ya go: http://www.harborfreight.com/air-needle-scaler-1108.html
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
Offline 81GMCBILL
Re: Frame paint
« Reply #7 on: August 17, 2012, 06:39:46 pm »
bake315> i see - thanks much for the info and place that has it.
Offline bake315
Re: Frame paint
« Reply #8 on: August 19, 2012, 09:54:17 pm »
No probs - glad to help!
Offline Mike Phillips
Re: Frame paint
« Reply #9 on: September 04, 2012, 08:16:31 am »
I just restored the front frame rails on my 1978 project truck using POR-15 followed with Rustoleum Hammer Black.
I'm posting videos of each project I do to a YouTube Channel I created for this truck project.
Mike's Truck Projects
Next up we're removing the cab and the bed to finish the frame and make the custom mounts for the Dodge NP205 Transfercase.
Offline Senck243
Frame paint
« Reply #10 on: September 04, 2012, 12:51:46 pm »
I used a kit from Eastwood with rust neutralizer, encapsulator, and a top coat. Very nice and easy seems very tough
1984 k10 305, sm465, np208
