Author Topic: Clunking when shifting into drive or reverse...  (Read 3282 times)
Offline Sodium Duck
« on: July 25, 2012, 01:39:45 pm »
When I shift into drive or reverse, I get a minor clunk/lurchy kinda of sound/movement. 700R4 tranny.
I happen to be changing out my driveshaft ujoints, so I have a chance to play around with the pinion flange on the rear axle. I know there isn't really a spec or measurement for backlash, unless I pull the diff apart... but I can rotate the pinion flange probably a good inch or so. It does not move in any other direction. I can not budge it in or out, side to side even if I try to move it that way. It just rotates. Is there a certain way it should feel? Am I over reacting? Is there anything else I can check at this point with the drive shaft out?
1985 K10, corporate 10-Bolts front and rear, 6" lift, 35's, 305, auto, longbed.
Offline Fairlane514
Re: Clunking when shifting into drive or reverse...
« Reply #1 on: July 25, 2012, 02:56:23 pm »
Its probably your U joints, so see what it does after you change them.
Backlash and improper gear tooth engagement will result in a whining noise. If you didn't have enough preload on the pinion (you can measure with an inch pound torque wrench, wheels off) you would probably hear a whining noise as well.
Offline clay7
  • farm boy
« Reply #2 on: July 28, 2012, 04:18:25 pm »
throttle pressure could be set too high on your trans
if you cant win,cheat. if you cant cheat,DONT PLAY!
Offline slammed79
  • Thou shalt not drive stock
« Reply #3 on: July 29, 2012, 12:59:18 am »
I'm gonna agree with fairlane and add you may want to check your transmission mount while you're under there.
Praise the lowered
