Author Topic: any one out there with pics of there 3/4 drops  (Read 5659 times)
Offline lotopp79
« on: April 05, 2005, 05:51:00 am »
I was woundering if any one out here had picctures of there 3/4 drop they could post want to know if it will be low enff I had a truck with a 5/5 but was thinking about backing it off
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
3/4 drop pix
« Reply #1 on: April 05, 2005, 11:17:00 pm »
Check out my site...I just got the rear done the full 4'' about 2 weeks ago. Had to upload the pix. Page 4 or 5 should have some shots of it with the 2'' hangers installed for the full 4'' rear drop. I'll warn you, though. It'll have a slight rake if you have the towing package on your option sheet. I found that out the hard way after lowering mine and then counting the leafs. It says it on a sheet right on the fender "heavy duty rear suspension". I guess the original owner or the dealership ordered mine as a work truck. Oh well. Hope this helps!
-Mike
www.cardomain.com/memberpage/788720
Offline lotopp79
Re: any one out there with pics of there 3/4 drops
« Reply #2 on: April 07, 2005, 05:54:00 am »
so in other word 3/4s gonna be level if i dont have extra leafs
I really like the factory rake
Offline roundedline
« Reply #3 on: April 07, 2005, 04:23:00 pm »
If you want to keep a rake in it you need to drop front and rear the same.  IE 4/4.  3/4 is the closest to the factory rake since the rear will still be a little higher.  3/5 will make it close to level since there is about a 2" diff from factory.  Keep in mind not every truck is the same and could differentiate up to 1" or so due to spring fatigue.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
