Author Topic: convert sm 465  (Read 4868 times)
Offline necromonger
convert sm 465
« on: July 31, 2012, 03:01:48 pm »
the trans is bad in my 2wd i have a trans out of a 4 wd it had a np205 t case what will have to do to put the 4 wd trans into my 2 wd?
new build,1978 chevy 3/4 ton 2 wheel drive 350 4 speed trans.
Offline starkey
Re: convert sm 465
« Reply #1 on: July 31, 2012, 04:28:08 pm »
if you still have the transfer case, you could slap the 4wd transmission and transfer case into your 2wd truck pretty easily. You'd just need the driveshaft from the 4wd truck. Only thing I see a problem with is cutting your floorboard out for the transfer case shifter. Would be pretty cool, you'd have a double underdrive granny gear! haha! Probably wouldn't hurt to grab the crossmember from the 4wd truck, just to be safe, but I think they utilize the same one.
If you don't have the transfer case, then I'm not sure it'd work, unless you have a slip joint in the driveshaft itself, since the 4wd sm465 is a fixed rear yoke.
1974 Chevy C20 Camper Special
350 w/ center bolt heads
T400 transmission, 14 bolt rear w/ factory 4:56s
Offline nvrenuf
  • Bazinga!
    • Project Pics
Re: convert sm 465
« Reply #2 on: July 31, 2012, 06:10:15 pm »
It's a tough swap, a 2wd 4spd has a short 35 spline tailshaft where your 4wd will be either short 10 or long 32 spline. You'd have to find a 2wd tailhousing and figure out the tailshaft issue.
Imo, it'd be easier to fix yours or find a used one.
John
'91 K5 454, 4spd, Dblr, J76, 70HD, 5.86's & 43's
'06 Dodge MegaCab
'06 Jeep Rubicon Unlimited
Offline Jason S
Re: convert sm 465
« Reply #3 on: August 01, 2012, 11:31:51 am »
Around my parts, the 2WD SM465 is fairly plentiful. I'd think if you just want a good transmission that swapping in another 2WD SM465 would be quicker, easier and possibly cheaper than converting the 4WD SM465 to a 2WD version or installing the SM465/NP205 into your truck.
