Author Topic: alternate brake hose  (Read 8318 times)
Offline Starlifter1
« on: April 16, 2005, 06:57:00 pm »
Hi Guys
So I'm in the process of dropping my 73 stepside and I ran into a slight problem you guys might have experienced.  The stock brake hose lower part is angled and hits the upper spindle.  I ordered the Earl's braided lines from Summit racing but stock bolts is too big for the hole ( wrong part maybe ).  Who else do you recommend for my next option?
thanks
Willie
« Last Edit: July 17, 2017, 08:20:23 pm by bd »
Offline roundedline
Re: alternate brake hose
« Reply #1 on: April 18, 2005, 12:31:00 pm »
I get all my braided hose from www.inlinetube.com  The main reason it probably doesn't work is because it angle into the caliper instead of away from the caliper.  The probably made it the same as a 4x4 which is wrong.  You typically have to tell them where the connection has to angle.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
