Author Topic: no passing gear  (Read 7642 times)
Offline 76StepSd
no passing gear
« on: August 04, 2012, 08:35:54 am »
76 Stepside C-10 with a early to mid 80's 350....700R4 transmission(4L60). Not sure if i have a dent cable problem or what...the transmission shifts fine though, but when you step on the gas it does not down shift (no passing gear). I am not an automatic transmission guy... i have little experience on them other thean R&R. Would like to find the prob mine is having.
Offline sbx22
  • 1974 1/2 ton 350 sbc
Re: no passing gear
« Reply #1 on: August 05, 2012, 01:45:12 am »
Have you tried adjusting the detent cable? I ran into this problem on my 350/350 combo, now it downshifts great! You can google how to adjust detent cable, or I think there's a thread on here?
Offline gunrac
Re: no passing gear
« Reply #2 on: August 05, 2012, 09:03:17 am »
If indeed u have the overdrive , it is probably the 700r4......the 4l60, which is basically the same tranny but is  electronically controlled. It wasn't introduced until 90'.
Providing u are using the correct hardware w/the correct carb. the following link will get u started......Google 700r4, or try the search on this site......lots of info and ability to find the correct kit, for the carb. u have, if u need ...... I'm currently going thru the tweeking process after the initial set up, for my 700.......I followed this, and it worked just fine......
http://forum.73-87chevytrucks.com/smforum/index.php/topic,7133.0.html
Never Apologize..........as it shows signs of weakness
Offline 76StepSd
Re: no passing gear
« Reply #3 on: August 05, 2012, 07:58:44 pm »
Yeah i got the Holley kit for the TV cable. Had to modify it some...i got a Holley 80555-1 carb. Will install tomorrow and give and update.
Offline 76StepSd
Re: no passing gear
« Reply #4 on: August 08, 2012, 09:35:05 am »
installed the bracket used for a Holley with the 700R4 seems to have somewhat of a passing gear but i need to drive it some more to see.........i only zipped around the block with it.
