Author Topic: Cooling System Q  (Read 4775 times)
Offline kwikshifter
Cooling System Q
« on: August 04, 2012, 01:16:37 pm »
I picked up an 86 longbed (350/350 combo).  It's been sitting a while and I've been fixing little things.  Has a cooling problem which may end up being a stuck thermostat.
However the rad cap was bad and I noticed it says 15lbs pressure/ closed system.  The overflow tank is not stock.  Has a tube from the rad to the bottom of the overflow tank.  Also has a relief tube at the top and a vented cap.
Question is should I block the relief tube and put a nonvented cap on the overflow tank?  Or is it fine as is.  Thanks, Gary
Pic.....1. vented cap
         2. relief hose
         3. input from rad
« Last Edit: August 04, 2012, 01:29:17 pm by kwikshifter »
Re: Cooling System Q
« Reply #1 on: August 04, 2012, 01:26:26 pm »
Fine as is.  The tank has to be vented or coolant won't flow correctly between the tank and radiator.
« Last Edit: August 05, 2012, 01:11:52 pm by bd »
Offline kwikshifter
« Reply #2 on: August 04, 2012, 02:16:14 pm »
I'd hoped so.  It would force coolant to leak thru the cap.  Although I'd had the cap off a couple of times, I did not notice that the rubber ring inside was only half there.
Offline gunrac
« Reply #3 on: August 05, 2012, 09:45:39 am »
I'd start with changing out thermostat and rad. cap. Pretty cheep reassurance knowing those 2 things are good to go.
Never Apologize..........as it shows signs of weakness
« Reply #4 on: August 05, 2012, 10:35:16 am »
you can get bad new parts.
« Reply #5 on: August 05, 2012, 01:14:20 pm »
Why do you think you might have a stuck T-stat?  Did the radiator cap fix your problem?
