Author Topic: Rear Brakes locking  (Read 10108 times)
Offline scott dale
Rear Brakes locking
« on: June 09, 2005, 01:57:00 am »
Anyone know what makes rear brakes lock up under hard braking? I welcome any and all suggestions. Rear brakes are all new front pads good but it did it before new rear shoes were installed.
Offline shaved80
Re: Rear Brakes locking
« Reply #1 on: June 11, 2005, 11:51:00 pm »
no abs?
Offline bigblock73
  • Yeller
« Reply #2 on: June 12, 2005, 09:23:00 am »
If you axle seals are leaking and getting gear lube on the shoes...that would cause the rear to lock up easy.  This happened to me after a gear change once.  Check out everything back there closly.
If everything checks out fine, perhaps you should try this...
www.73-87.com/7387garage/...on/lbs.htm
...Jeff
'73 swb 2wd
'77 Blazer 2wd
73-87.com
Jeff
'73 swb 2wd
73-87.com
Offline J G Davis
Brakes locking
« Reply #3 on: June 17, 2005, 05:14:00 pm »
Scott, I've been having the same problem. I put a post under the body section of the web site. I'm about to change the master cylinder. I don't think I'm getting too much pressure to the rear, as they don't lock up till I'm pushing pretty hard on the pedal. I think i'm not getting enough pressure to the front, so i'm going to replace the master. I have to start someware and that is my best guess. I've got manual brakes, but they should still stop better than they do.I was told there was a tech service bulletin out during the 80s on that, but I can't find any info on it.
             John
