dana 44 front axle
Topic: dana 44 front axle (Read 7474 times)
gcochran223
dana 44 front axle
August 15, 2012, 11:56:05 am »
i have a 86 k15 6 lugs,12 bolt rear and i assume a d44 front. i have a pic posted of the from diff cover.im concerned how well this is going to hold up to my 350 with probably 330hp 350 ft lbs, i have a built th400 and np205. its the 6 lug dana 44.axles are stock with 3.42or 43s? cant remember but running my 35s im sure there is a gear swap in my future with 4.56 or 4,88s. the problem is i plan to occasionally use the truck for concrete tug a truck pulls. i have looked for a dana 60 14 bolt swap but the prices are really high and i would think a dana 60 would break also if its weak. i have tossed the idea of doing gears and chromoly shafts in the front but i hear still those will break when abused but i guess anything will break when abused. the main reason i want to stick to my 15s is i have 3 sets of tires that are practically brand new on good rims i have aquired over the years.31s,35s and 37s. just wondering what recommendations anyone may have with experience in the upgraded shafts and gear swaps with these chevy axles. also fyi i believe axles are open diffs anyway.its not a dedicated pull truck but after a few beers and peer pressure anything can happen, thanks ahead.
1986 k15, 355, th400 ,np205, Corporate 10 bolt,corporate 12 bolt, 8" suspension lift.4.56 yukon gears.
thirsty
Re: dana 44 front axle
August 15, 2012, 08:41:51 pm »
Original to your truck would be a 10 bolt.
I think the easiest and cheapest way to guard against "
" would be to have another 10 bolt with the same ratio sitting around in case you broke yours. You could swap it out in a few hours and look like a hero again to your peers if need be.
BTW...you wouldn't be the first person to wreck a differential because of beer and peer pressure.
Years ago my dad suggested that I install my drive trains with wing nuts on everything so I could change them out quicker. lol I used to break my share of parts back then.
Build thread
gcochran223
August 15, 2012, 09:27:29 pm »
is that the dana 44 bolt pattern? my 78 had a 10 im pretty sure and it was almost a circle shape.thanks for the input!
Sartobuilt
August 15, 2012, 09:52:56 pm »
That is a 44 that you have.
X2 on the spare parts, Get a spare axle.
Blazin
Blazin new trails!
August 17, 2012, 06:52:25 am »
Over the years I have wheeled the wee out of, and abused many 44s. I will tell you I also broke some of them! But all and all they take quite a bit before there is a real problem.
gcochran223
August 17, 2012, 04:05:12 pm »
yeah it wont be mudding running large tires but more tug a truck and maybe pulling a sled just to see how it does.it just makes me nervous cause alot of people are dana 60 or nothing and in NW ohio a junkyard dana 60 is atleast 600.thanks for the info guys
Blazin
Blazin new trails!
August 18, 2012, 07:33:13 am »
I agree with the Dana 60 or nothing theory, but 44s and 10 bolts have there place as well. A good 60 around here can bring $1,000 or more if its had new parts installed.
dana 44 front axle
