Author Topic: another trans question  (Read 5408 times)
Offline str8bloc
  • MISTRESS
« on: August 15, 2012, 07:56:27 pm »
i have a 700r4 and smells burnt. should i change the filter and fluid or leave it alone?
FaTbOy
Re: another trans question
« Reply #1 on: September 05, 2012, 10:51:17 am »
What color is the fluid?  Is it slipping?  When was the last time it got changed?
Offline str8bloc
  • MISTRESS
« Reply #2 on: September 07, 2012, 07:33:19 pm »
fluid is pink i changed it and filter a week ago burnt smell is less.tranny hasnt slipped or anything still works great.just worried about the smell.it used to be a big nasty smell,but not i cant smell it unless i pull the dipstick but levels great and has a faint smell
FaTbOy
« Reply #3 on: September 10, 2012, 03:59:28 pm »
What color was it before you change it?  If it isn't slipping you should be ok...
« Reply #4 on: September 10, 2012, 05:02:25 pm »
Keep in mind if you just pulled the trans pan and changed the fluid/filter that didn't change all of it.  The torque convertor holds about 4 quarts just by itself...
Offline str8bloc
  • MISTRESS
« Reply #5 on: September 10, 2012, 08:07:55 pm »
how can i change all of it
FaTbOy
« Reply #6 on: September 11, 2012, 11:30:20 am »
you have to drain the converter.
Offline 454Man
  • Why Race?
« Reply #7 on: September 11, 2012, 01:28:54 pm »
Here its a trick I learned from an old wise man... Take off both Trans cooler lines from the radiator, put the bottom one in a bucket and the to one in a bucket of Trans fluid turn the engine on and keep filling the bucket up with Trans fluid till the bottom line is a good red color. Did this to my other vehicles its not to hard.
Offline str8bloc
  • MISTRESS
« Reply #8 on: September 11, 2012, 04:41:57 pm »
thankz 454 ill do that this weekend
FaTbOy
Offline 454Man
  • Why Race?
« Reply #9 on: September 11, 2012, 05:35:37 pm »
No prob. all you need is some hoseclamps and some hose. No need to pay a shop I if you can do it yourself
