Author Topic: TH400 Shifting Issues  (Read 3155 times)
Offline RossChampion
« on: August 21, 2012, 01:41:18 pm »
Turbo 400 mated to a new (about 1500 miles) mildly built 400ci small block in an 86 c20.
When cold it shifts fine, as it comes up to temp the shift point goes from it's typical shifting pattern to shifting at about 3500 RPM.  There is no engine breaking like there would be if I were manually shifting, or what I would expect if it were just stuck in gear.
I replaced the modulator and inspected the vacuum line.  Line is good and new modulator did not make any difference.  Fluid levels are good.  I did find that one of the lines leading to the trans cooler was very slightly kinked, probably happened during or shortly after the new motor was put in.  I straightened it back out and it should be flowing well.  The electronic kickdown is not working (that was next on the list to sort out) and I have not yet trouble shot what is going on there.
Any idea what is going on?
« Last Edit: August 21, 2012, 01:44:50 pm by RossChampion »
Re: TH400 Shifting Issues
« Reply #1 on: August 22, 2012, 02:35:39 pm »
Looks like the cooling line was kinked worse than I thought.  So hopefully this was just a case of low hydraulic pressure.  But I will report back in case anyone cares.
« Reply #2 on: August 22, 2012, 02:43:56 pm »
I bet whoever read it, 27 as I write, cares about the solution.   It is just that we who have read it don't know the answer or where to start.  Please keep us updated...
« Reply #3 on: August 29, 2012, 04:50:57 pm »
Is the fluid burnt?  Was the tranny already in and you just replaced the engine?
