Author Topic: Stuck truck recovery...  (Read 4296 times)
Offline Sodium Duck
« on: August 23, 2012, 06:53:19 pm »
I'm slowly getting into wheeling with my truck. Nothing too crazy yet, but if we have another rain storm up here... the mud is gonna start flying.
Today I picked up a recovery strap and some pin shackles for it.
I thought this video was really good for a starting point:
http://www.youtube.com/watch?v=vWlcGCzbyLo
But does anyone have some tips on recovering our trucks specifically? I'm more stuck on good recovery points to attach my strap to. The reason I bought the shackles was because I only have a heavy duty drop bumper at present in the rear. I figured I could attach the shackle to where the ball mount is supposed to go.
Later on down the road I will buy/make some beefy bumpers and put hooks on them. But until then, I want to be safe with what I have.
1985 K10, corporate 10-Bolts front and rear, 6" lift, 35's, 305, auto, longbed.
Offline bigchevyc30
  • the pig
Re: Stuck truck recovery...
« Reply #1 on: August 23, 2012, 09:32:51 pm »
well when my dually got stuck in the mud the guy that pulled me out hooked it right to the crossmember on the front of the truck so that being said if its a big cross member just hook it to that cause he had some good running starts and got stopped real quick from the weight of my dually so and also if u have a tow hitch say the 10k ones then just hook to that if needing pulled from the rear
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Offline ssapach
« Reply #2 on: August 23, 2012, 11:36:48 pm »
If you ever have a receiver on your truck, don't be tempted to simply put the strap into the receiver tube and slide a pin through.  You can bend the pin and then have it stuck in there.
Be very careful what you hook things to.  I have a set of J-hooks, like what most tow trucks will have, and I thought I could simply put one of the hooks into a hole on the frame of a truck and give someone a tug.  Well the hook ripped right through about 2" of the frame metal on the front end of the truck......with lots of people standing around watching, it's a good thing nobody got hurt.
Your axles can be very solid points for recovery as well.  There is a reason why I see large trucks that have the cable's slung through the front bumpers and hooked onto the rear axles, so when you pull on the cable you are actually helping to move the axle forward (hopefully to a better traction spot).
If you're trying to pull someone out with a jerk, it's best to have a proper strap for it.  You can actually buy "kinetic"recovery straps that have more stretch than a basic sling or tow rope.  Chains are terrible for a running tug, cable isn't any better.  That being said, it never hurts to have a winch weight to throw over winch cables.  Or if you prefer some fancier recovery equipment, synthetic winch lines are available that don't stretch and store energy the same way a steel winch line will.
One important thing about wheeling, you don't want to have the biggest, heaviest vehicle around.  You don't want to be "that guy" who got stuck and nobody could pull out because you had the biggest and heaviest vehicle. ;D
