Author Topic: 89-91 Silverado front end versus the 81-87 quad light front  (Read 15405 times)
« on: August 25, 2012, 10:44:58 am »
I am at a place in my 1985 C20 Scottsdale facelift and want your guys opinions regarding what I should do....  The picture is showing where I am at.  I found the core support section where the inner fender well bolts to it having some rust issues.  I have a replacement fender and new GM inner as well as a very nice battery tray.  I have heard that the 89-91 lights on the newer front end are not the best but I really like the appearance of them.  I have squirreled away two complete core supports in both styles.  I know the quad set up works great for lights especially when all 4 are on.  Anyone who has done the conversion please post your opinions...
Offline slammed79
  • Thou shalt not drive stock
Re: 89-91 Silverado front end versus the 81-87 quad light front
« Reply #1 on: August 25, 2012, 01:40:59 pm »
I haven't done the swap myself, but I love the 89-91 gmc setup, especially on a truck.
Praise the lowered
Offline Edahall
« Reply #2 on: August 25, 2012, 11:02:19 pm »
Yes, the light output is so bad it's a safety issue IMO.  To fix that issue on my 1990 Suburban, I installed a set of Hella headlights and relayed them.  It was somewhat costly for the Hella headlights but the difference was highly worth it.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline Townsend600
« Reply #3 on: August 27, 2012, 05:27:34 pm »
I would go for either and just convert them to HID's and put a phantom grille over it.  Hide it all.
« Reply #4 on: August 28, 2012, 05:06:20 pm »
You can get around the bad lighting as stated, go with the one you like.
I prefer stacked at over the 89-91 at this point in time.  12 year ago, it was the other way around.
« Reply #5 on: August 28, 2012, 09:31:57 pm »
Thanks guys for the comments.  I figured out what I am gonna do.  It was right under my nose.  I will update my project with pictures when I go there...
Offline rs74
« Reply #6 on: September 03, 2012, 09:11:53 am »
I like both but prefer the quad setup. The truck has to have the right look in order for me to like the newer setup.
« Reply #7 on: September 03, 2012, 10:05:56 am »
I have decided to keep what I have, fix it with a repair section section cut off from my 86C10 which the 91 front was for anyway.
Offline Cabcorner
« Reply #8 on: September 05, 2012, 07:55:30 pm »
        Good call I'm getting sick of all the 89-91 front end swaps . How did this get in the engine drivetrain section?
« Reply #9 on: September 05, 2012, 08:20:20 pm »
My bad, I asked the mods once I figured I put it in the wrong spot to put it in the body section, eventually it will get moved
« Last Edit: September 05, 2012, 08:31:11 pm by zieg85 »
« Reply #10 on: September 06, 2012, 11:25:42 am »
Oops, I dropped the ball on moving it.  Sorry...
Offline big bear
« Reply #11 on: September 06, 2012, 04:02:08 pm »
I am huge fan of quad headlight setup. I cannot stand the  89-91 front.just my opinion.
