Author Topic: thinking about lowering my 84 swb  (Read 17659 times)
Offline greatdane
« on: August 27, 2012, 09:38:12 am »
 Thinking about a 3 & 4 inch drop.
Would 3" drop spindles and 2" shackles & 2" hangers be the best way for good ride quality? Drop coils are cheaper but I have heard if you use 3" ones your ride can be bad!? Can you use your stock shocks and everything with a 3,4 drop?
« Last Edit: August 27, 2012, 09:40:09 am by greatdane »
'74 AMC Matador 2dr Coupe
Re: thinking about lowering my 84 swb
« Reply #1 on: August 28, 2012, 05:17:40 pm »
I would recommend spindles and shackle/hangers for a good ride, you don't want to use 3" drop springs.
Offline greatdane
« Reply #2 on: August 29, 2012, 10:03:20 am »
Ive been researching 5" flip kits. I may go 3-5. How does that look? I don't like the rearend looking "saggy" though. Also I don't want to have to buy different tires in the front so I dont think I should go more than 3 to 3 1/2" up there....
« Last Edit: August 29, 2012, 10:47:37 am by greatdane »
« Reply #3 on: August 29, 2012, 01:38:44 pm »
A 2" difference generally puts these trucks almost level, a 3/5 will look better in my opinion.
Offline greatdane
« Reply #4 on: September 13, 2012, 02:01:06 pm »
Looking at 3" drop spindles on Ebay. Ever heard of springtech or crown suspention? They are cheaper than the rest, wonder if its junk?
« Reply #5 on: September 13, 2012, 02:55:14 pm »
Nope.  I generally stick with Belltech, DJM, McGaughy or Western Chassis (in no particular order)  I have even used AIM with good results.
Offline greatdane
« Reply #6 on: September 18, 2012, 04:34:37 pm »
Just ordered a DJM 3/4 drop kit. Should arrive Monday. Hope to have it on by the end of the month.
Questions:
Do 3" spindles effect anything like...brake lines or make anything rub(I have 17" wheels)?
Can you run your stock shocks with 3" spindles and 4" shackles & hangers?
I dont want any surprises  :o
« Last Edit: September 18, 2012, 05:08:46 pm by greatdane »
Offline jt1200r
« Reply #7 on: September 20, 2012, 05:47:34 am »
stock front shocks will be ok. the rears will need new.
87 R10 4.3
Offline greatdane
« Reply #8 on: September 27, 2012, 10:36:46 am »
Teaser pic... 3" in Front and 2" in Back. Still have to put the hangers on to get the back down 2 more inches...
Offline greatdane
« Reply #9 on: September 29, 2012, 08:31:48 am »
Before & After
Offline Tx_Phil
« Reply #10 on: September 29, 2012, 01:24:55 pm »
Generally speaking I don't care for lowered trucks but this one looks really good. In my opinion you've got the right proportion of ride height and wheel \ tire size.  Nicely done !
Offline greatdane
« Reply #11 on: September 29, 2012, 09:09:51 pm »
Thanks, i think it turned out good. I may go down one more inch in the front later but Im going to run it lke this until I get it painted. A couple more pics...
Offline 70fastback
« Reply #12 on: October 01, 2012, 02:43:55 pm »
I think it looks really good too!!! It's funny when I first saw the pic, prior to reading your comments, I thought it could go down a little bit more in the front.  How do you plan on doing that???  Cut some off the coil spring???
Offline greatdane
« Reply #13 on: October 06, 2012, 08:35:44 pm »
Cutting half a coil or buy 1" drop coils??? I don't want my ride to suffer, the truck is actually riding pretty good since we put the drop on it. Does cutting 1/2 to 3/4 off a coil hurt the ride much? Also my alignment shop said they would never get it aligned if I messed with the coils any!!? Because they have all the shims in it they can have already!? How bad will it throw the alignment off? Would drop coils or cutting them be the best way to go? I'm kinda leaning towards just leaving it alone LOL.....
« Reply #14 on: October 12, 2012, 09:59:52 am »
If you just want to go down 1", 1/2 a coil is about max.  Start with 1/4 and drive it and see if you like it.
