Author Topic: Inner rocker measurements  (Read 8247 times)
Offline hotrod24
« on: August 27, 2012, 09:50:18 pm »
Ok I started making an inner rocker and I have all the peices made.  I just need some measurements of the flat flange and the part that supports the floor lengthwise...
1978 pontiac grand prix...
Re: Inner rocker measurements
« Reply #1 on: August 28, 2012, 05:02:22 pm »
You want to know what size the replacement is, or how long you need it?
Offline hotrod24
« Reply #2 on: August 29, 2012, 12:10:46 am »
I know the replacement is 33.5 inches long and  6.5" wide. I need to know what the measurements are for the part that steps up in to the floor and the flat flange that stick up lengthwise. I am not sure if they are split up right in the middle or are different lengths. I also need to know how tall the flat flange is...
Offline Fairlane514
« Reply #3 on: August 29, 2012, 06:34:46 am »
Maybe I'm missing something here, but if you are repairing rust, cut out the offending area (hopefully less than the new replacement) and then trim your patch panel to fit.
Offline hotrod24
« Reply #4 on: August 29, 2012, 12:41:33 pm »
That would be great if I could do that. But I dont have a welder. all I am using is rivets...
Offline hoops1
« Reply #5 on: August 29, 2012, 01:20:22 pm »
If you don't have a welded don't do it rivets will never hold it
« Reply #6 on: August 29, 2012, 01:30:28 pm »
Those 2 lengths are pretty much split.  If you aren't going to weld it, use panel adhesive.  You will be doing this again if you use rivets.
Offline hotrod24
« Reply #7 on: August 29, 2012, 02:07:36 pm »
Ok thanks Chris for the info on the inner rocker. But yea I was not really sure about just using rivets. I thought about using rivets and self sheet metal screws. Could I use the rivets and screws along with the adhesive?
« Reply #8 on: August 29, 2012, 02:57:40 pm »
If you use panel bond adhesive you won't need any screws.
Offline hotrod24
« Reply #9 on: August 29, 2012, 03:37:48 pm »
So chris you are saying that I could use rivets with the screws or rivets and the adhesive?
Offline Fairlane514
« Reply #10 on: August 29, 2012, 03:44:51 pm »
This is a great opportunity to learn a new skill......Welding!    Welding is the BEST way to perform this repair.  Being able to weld will open up a whole new world to you and what you can fix or create.
Offline hotrod24
« Reply #11 on: August 29, 2012, 04:32:16 pm »
Yea it would be a great way to learn because I have not pickup a welders sence high school lol.  But that is going to have to wait because I dont have no way of getting a welder right now. I wish did have a way so I could do it right the first time...
« Reply #12 on: August 29, 2012, 05:02:41 pm »
Just the adhesive, no screws or rivets.
Offline hotrod24
« Reply #13 on: August 29, 2012, 05:57:53 pm »
Ok how about the floor support and the kick panel?
Offline jaredts
« Reply #14 on: August 30, 2012, 03:38:13 pm »
Just an opinion:  I've seen plenty of floor patches and even small rust repair panels put in with rivets.  They don't hold up too bad.  Rockers and floor supports are a little too structural to not use a welder.  Panel bond is strong stuff but I have a hard time picturing it on an inner rocker or floor support.  Floor patch, outer rocker, you could use it.  Bolts and nuts on both ends of the floor support and panel bond everywhere else should work, I guess.
