Author Topic: Trying to match this setup.  (Read 8930 times)
Offline rs74
« on: August 29, 2012, 08:59:01 am »
I know it is hard to say but if you had to guess then what size lift, rims and tires would you say is on this truck. I am thinking it is a 6 inch lift maybe but not sure about the rims/tires.
Offline 454Man
  • Why Race?
Re: Trying to match this setup.
« Reply #1 on: August 29, 2012, 09:20:55 am »
Id say 4 in body lift with 35 in tires :-)
Offline rs74
« Reply #2 on: August 29, 2012, 09:29:14 am »
Do you think they are 16's?
« Reply #3 on: August 29, 2012, 01:42:39 pm »
If that is a body lift someone spent some time making the bumper match, looks like a 6" lift to me, hard to tell on the rim size, but it looks awesome.
Offline timthescarrd
« Reply #4 on: August 29, 2012, 04:13:13 pm »
Definitely looks like a suspension lift not body,   The 4th gen Camaro in the background has 16" rims, the ones on the truck look a hair smaller so I would guess 15".  Stock tires on the Camaro are 235/60/16 so about 27" height so those on the truck are probably 33/10.5/15
Offline ehjorten
« Reply #5 on: August 30, 2012, 01:38:22 pm »
Mine's 8" lift with 35s.  I would say that is 6" lift with 35s and the rims look like 16s based on the proportion of sidewall.  Gonna be a little cozy with the front tire.
http://forum.73-87chevytrucks.com/smforum/index.php/topic,19098.0.html
-Erik-
« Reply #6 on: August 30, 2012, 11:32:23 pm »
31-32 then you have tire wear/16 is more like it. something photoshop is go0d for is telling you sizes of a area. the front hub for example is about 4.5" in real life but the pic im seeing is about .4" and since 3/4-1tons most time have 16 or bigger rims these rims measure about 1.4+ they are about 16",  which means the ratio is 1:11.25 .the highest part of the fender is about 42.75" now i dont have a stock 4x4 around here but if someone would measure theirs the difference should be about the lift height. its hard to see in detail the exact size  but i think its close enough since 3/4 and 1 tons come with 16" or bigger rims
« Last Edit: August 30, 2012, 11:36:16 pm by Irish_Alley »
« Reply #7 on: August 30, 2012, 11:52:36 pm »
Just went outside and looked at my truck. 3/4 ton with 38s 6" lift its sitting at 48 or so. So withe the 6" tire difference that would put me at 42 with 6" lift
Edit: it was late and i wasnt thinking right but the tire difference is only 3" radius so its more likely a 4" lift
« Last Edit: September 05, 2012, 08:49:22 pm by Irish_Alley »
Offline 81_Chevy
« Reply #8 on: October 29, 2012, 01:15:30 pm »
6 inch, you can see the back blocks and the steering shocks.
looks like 16 inch wheels with 33's or 35's.
