Author Topic: frame and cab interchangability  (Read 5915 times)
Offline rs74
« on: September 02, 2012, 08:56:40 am »
Will an 87 cab fit onto a 78 frame. My thought is yes but wanted to make sure.
Re: frame and cab interchangability
« Reply #1 on: September 02, 2012, 08:59:08 am »
yes
« Reply #2 on: September 02, 2012, 11:19:20 pm »
You will need to use the 73 to 80 style cab mounts.
Offline rs74
« Reply #3 on: September 03, 2012, 08:02:25 am »
Thanks, thats the type of info I was looking for.
Offline Bobs85PU
« Reply #4 on: September 22, 2012, 10:36:59 pm »
By "cab mounts", do you mean the rubber cushions and associated hardware....Or, do you mean the brackets attached to the frame?
I'm asking because I'm intending to swap my 85 1/2T body and bed to a 1980 3/4T chassis...I hope!!!
« Reply #5 on: September 23, 2012, 11:55:23 pm »
Cab mounts are the rubber and steel bushings that go between the cab, and the brackets that are rivited onto the frame.
Offline Skyshadow
« Reply #6 on: September 25, 2012, 11:02:55 pm »
Just started another thread about interchangeability of certain cabs to certain frames. Some savvy person on here should make a wheel base length, frame length, etc list so we can play around with the ideas
