Author Topic: REar End Swap  (Read 3318 times)
Offline kwikshifter
REar End Swap
« on: September 06, 2012, 07:39:44 pm »
86 Longbed....350/350 combo.  There are some nasty clanks in the back when I let off the gas. Thinking there is something astray in the rear end.  I can get a complete rear less drums for $65 at the local upull.  Seems easier than taking mine apart and investigating and fixing. The PO may have been a bit rowdy with it.
Question is what years will be the same to fit in.  It's flipped so I'll need to weld pads onto the new one.  Ratios are not important to me, just that the entire rear will swap easily.
Offline Fairlane514
Re: REar End Swap
« Reply #1 on: September 06, 2012, 08:27:43 pm »
You could check your U joints first. Does it clunk when you put it in gear?
Offline str8bloc
  • MISTRESS
Re: REar End Swap
« Reply #2 on: September 07, 2012, 07:46:01 pm »
i had the same problem years ago it was my pinion nut came loose better check it soon. i still drove it after i tightened it
FaTbOy
Offline CruzinHigh
  • Chevy 4 life
Re: REar End Swap
« Reply #3 on: September 08, 2012, 07:54:48 am »
Where are you located?  If you needed to change the entire rear out I'd consider GIVING you my old 10 bolt I plan to swap out for a 14FF soon.
Mike Carter
1986 Chevy K-10 4x4
Re: REar End Swap
« Reply #4 on: September 10, 2012, 03:53:41 pm »
1981-1987 1/2T 10 bolt.
