Author Topic: anybody body dropped with pics?  (Read 16152 times)
Offline dragit
« on: December 05, 2005, 01:16:00 am »
I am currious about one cut in paticular, that being the firewall
any info or advice would be greatly appreciated, i dont want to ruin the cab.
91 toyota (fast bagged)
77 C10 fresh 350/350
80 suburban 4x4
Edited by: dragit at: 12/5/05 1:19 am
Offline roundedline
Re: anybody body dropped with pics?
« Reply #1 on: December 05, 2005, 09:57:00 am »
It is much simpler to just Z the frame, or notch the crossmember.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline dragit
« Reply #2 on: December 05, 2005, 02:20:00 pm »
What do you mean by Z the frame? im not familiar with that term.
Offline roundedline
« Reply #3 on: December 05, 2005, 02:46:00 pm »
You cut the frame in front of the firewall and raise the whole frontend section up and reweld it back together.  Doing a Body drop is ridiculous when you can just Z the frame.  1/2 as much work and little fabrication.  Most do a bodydrop because it is a catch phrase.  Long time ago it was called channeling.
Here is good info on Z'ing.  It has been around for over 50 years.
www.loweredd.com/Frame_Z.html
Project Su
Jimmy 2WD Project
Offline dragit
« Reply #4 on: December 05, 2005, 10:07:00 pm »
thanx, now i see what you were saying, its basicly a stock floor bodydrop, cause your not loozing any head room, i think ill try that ,but one question. do you still have to raise the bed?
Offline roundedline
« Reply #5 on: December 06, 2005, 10:09:00 am »
Well, the body isn't "dropping", the Frame is getting cut, which is what is called Z'ing the frame.  As for the bed, it depends on how/how much you are dropping it.
Project Su
Jimmy 2WD Project
Offline shaved80
« Reply #6 on: December 11, 2005, 09:57:00 pm »
that guy cut his frame on the bottom to lay rocker :rollin
Edited by: shaved80 at: 12/11/05 9:57 pm
Offline RSBAD454
« Reply #7 on: January 07, 2006, 01:22:00 pm »
better to notch crossmember.....rear is of course the easier of the 2 to lower. I just have 3" Bell tech spindles, cut one coil from big block springs, rear Bell Tech flip kit and some leaf springs removed.
Toys are my game
Edited by: RSBAD454  at: 1/7/06 1:26 pm
http://
Offline DRAGGNC10
« Reply #8 on: January 08, 2006, 07:36:00 am »
stockfloord on 22s "Z"D frame
Edited by: DRAGGNC10 at: 1/8/06 7:37 am
Offline RSBAD454
« Reply #9 on: January 08, 2006, 08:55:00 am »
that's just a bagged truck with no wheel wells.....a lot of work went into that.
Toys are my game
http://
Offline lotopp79
no thats a real body drop
« Reply #10 on: January 31, 2006, 06:39:00 am »
the sits lower then the body so the rockers would be like 2 or 3 inches off the ground
just pull the inner fender dosnt set tthe rockers on the ground
Offline shaved80
« Reply #11 on: February 01, 2006, 02:05:00 am »
i plan on sfbd'ing mine 3 1/4" soon...i was going to build a complete frame firewall back but ditched that idea
