Author Topic: '85 full size rear end problems  (Read 4773 times)
Offline Cynide357
« on: September 18, 2012, 05:21:15 pm »
I almost have my '85 paid off from a friend, and I'm ready to go pick it up.  From what I know, it drives fine in reverse, but when in forward, the right rear wheel won't spin.  It is a 4 wheel drive, by the way.
Offline Tx_Phil
« Reply #1 on: September 18, 2012, 05:38:36 pm »
It won't spin as in the engine can't make the wheel turn. Or it won't turn as in it locked up?
Offline Cynide357
Re: '85 full size rear end problems
« Reply #2 on: September 18, 2012, 06:03:59 pm »
Because it is locked up.
« Reply #3 on: September 18, 2012, 07:13:40 pm »
If it has sat a while the drum may have rusted up
« Reply #4 on: September 18, 2012, 07:26:32 pm »
Welcome to the site from Central California!
Any noises coming from the rear?
This ^^^^^
Or, might be that one brake is adjusted a little too tight.  Pull the drums to inspect the brakes, clean up the drums if needed, then adjust them on both sides.
Offline Cynide357
« Reply #5 on: September 19, 2012, 09:31:43 pm »
I'm going to look at it real close tomorrow.  More updates then.
