Author Topic: Cruise Control Help  (Read 5391 times)
Offline 86SilveradoEric
Cruise Control Help
« on: January 23, 2004, 12:14:00 am »
The cruise control doesn't work on my 86 anymore.  My dad can't remember if it worked when he got it or not, but it hasn't the whole 5-6 years I've had it.  I've checked to see that everything is hooked up, and everything underneath the dash seems to be, and all of the vacuum lines under the hood are hooked up, with the exception of one that doesn't directly connect to the servo.  I have it blocked off with a golf tee.  And there is also a small green wire that's hanging loose with an orange connector.  I know this has something to do with the servo because the same color green wire is on a connection clip that goes straight to the servo.  Do any of you know what to look for or do you have a link to a website that has a repair article?  Thanks guys!
Offline 77 K30 Crew Cab Dually
Re: Cruise Control Help
« Reply #1 on: January 29, 2004, 12:14:00 pm »
I have a similar problem with my 86 1 ton dually. Later on down the road I will be seeking the same information. Any help with our cruise control problems will be greatfully appreciated:rolleyes
