Author Topic: Need tips on dropping my 81 C-10  (Read 4745 times)
Offline dez81
« on: January 26, 2006, 09:02:00 pm »
Next up on my project list is my suspension. I want to drop 2 1/2 in front and 4 in rear. I want to order drop spindles for front and shackles and hangers for rear. I want to change out coil springs, leafs and shock in the process. What are some things I should look out for to make the job go smooth?
OKUMA111
  • Guest
Re: Need tips on dropping my 81 C-10
« Reply #1 on: February 19, 2006, 05:10:00 pm »
I HAVE A 81 GMC , THIS HAD A ROUGH HARD SUSPENSION I CUT THE SPRINGS ABOUT 1 1/2 TURNS THIS LOWERED THE TRUCK ABOUT 3'' NOW FOR THE REAR I STRAIGHTEN OUT THE LEAF SPRINGS NOTE THE STRAIGHTER THIS THINGS ARE THE LOWER THE REAR WILL GET. SO I GET A 3'' AND 4'' WITH OUT BUYING  ABSOLUTLY NOTHING.                                        NOTE: AND THE RIDE FOR SOME REASON IS ALOT SMOOTHER THAN ORIGINAL. NOT BOUNCY NOR STIFF.:hat                       I ALSO WAS ABLE TO PUT 22'' WITH  285-35-22 WITHOUT SCRAPING THE INNER FENDERS.
Edited by: OKUMA111 at: 2/19/06 5:13 pm
