Author Topic: Dash cover  (Read 5610 times)
Offline Magic1
Dash cover
« on: September 30, 2012, 12:15:29 pm »
Anybody had any luck with installing a cover over their dash? Way wondering how well they fit and if they cover everything nice and flush.
Offline PromiseKeeper
Re: Dash cover
« Reply #1 on: October 05, 2012, 09:48:42 am »
here's mine. making sure everything is level underneath will go a long way in how it turns out. By that I mean if you are bridging some big gaps, it can make things wavy.
Offline Magic1
Re: Dash cover
« Reply #2 on: October 05, 2012, 09:54:22 am »
That looks good. Did it come with glue and cleaner to install it with?  My dash now has a couple of cracks and the vent hole section on each end of the top is brittle and broke.
Re: Dash cover
« Reply #3 on: October 11, 2012, 11:29:04 am »
it came with a tube of silicone and instructions. As long as the cracks aren't too wide it shouldn't be a problem. My biggest problem was the thin area behind the defroster vents. I had to add some filler so everything would rest level.
Offline Mojoputter
Re: Dash cover
« Reply #4 on: October 11, 2012, 02:25:41 pm »
Where did you get that cover from..?
Re: Dash cover
« Reply #5 on: October 12, 2012, 07:54:09 am »
Re: Dash cover
« Reply #6 on: October 15, 2012, 09:10:24 am »
The insert on my dash was toast. Instead of replacing it, I used a piece of cherry wood I had laying around and put an emblem on it.
