Author Topic: lowering the rear  (Read 5960 times)
Offline 73stepside
lowering the rear
« on: February 26, 2006, 04:03:00 pm »
I have a 73 stepside C10 with 2in. dropped shackles and hangers.The leafs are about 2 years old and originally had 6 leafs.I dont haul heavy loads anymore since I completly restored the truck.If I had it to do over,I probably would have gone with a flip kit.My rear tires are 255 60 15.I had since removed 2 leafs from the pack.Each time my ride actually got smoother,and I gained little drop maybe an inch( i never took the time to measure,but I could tell it did drop a little).I would like another 1 or 2 inch drop to where the top of my tire is even with the bottom of  my fender well.Should I remove any more leafs? Is the bottom fat leave one that should not be removed? Thats the one I was thinking of removing.I haul a 5x7 trailer to the landfill occationally,not to heavy,just trash or tree trimmings.Any input would be appretiated.
Offline RSBAD454
Re: lowering the rear
« Reply #1 on: February 26, 2006, 08:56:00 pm »
I would get a belltech flip kit before you take out anymore leafs.
Toys are my game
http://
Offline roundedline
« Reply #2 on: February 28, 2006, 05:35:00 pm »
How many leafs total do you have now?
You can remove the overload with no problems, I personally wouldn't go less than 4 leafs on a 7 leaf pack.
If you want to go lower, you could get a set of rear shackles, but you will probably need to clearance the bed for them.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline bigblock73
  • Yeller
« Reply #3 on: March 03, 2006, 03:19:00 pm »
You WILL need to clearance the bed for drop shackles. :rolleyes
...Jeff
'73 swb 2wd
73-87.com
Jeff
'73 swb 2wd
73-87.com
