Author Topic: wiper question  (Read 5931 times)
Offline Low82C10
wiper question
« on: October 01, 2012, 08:24:45 pm »
what is the difference in wipers? as far as delay or intermitting....the reason i ask is, i have what i think is a two speed switch and its also a push button for the wiper fluid pump. i have the unit on the fire wall that im guessing is a all in one, wiper motor and pump. PO told me it has a 85/86 front end so im not sure if this is were the problem is, i also have a wiper fluid bottle with the motor mounted on it but the wires went to the bulk head and did nothing. my problem is....when i push the button in to squirt water, it just clicks. the pump wires in engine bay (pink,white)??? when i disconnect them only one has 12v when i push the button when the connector is connected they both have 12v and when i push the button one wire goes dead?
Re: wiper question
« Reply #1 on: October 02, 2012, 01:45:41 am »
The washer pump receives power whenever the ignition is on.  The washer switch completes the pump circuit to ground.  Sounds like you have a bad pump.
Offline Low82C10
Re: wiper question
« Reply #2 on: October 02, 2012, 05:55:21 pm »
can the pump be tested but using a battery positive to + etc
Re: wiper question
« Reply #3 on: October 02, 2012, 05:59:54 pm »
Sure.  Pink wire is positive, white wire is negative.  Supply power and ground to those two terminals, respectively.
