Author Topic: Fuel gauge reads correct but in wrong spot spot on gauge  (Read 8330 times)
Offline jackjeckel757
« on: October 06, 2012, 01:58:20 pm »
Would anyone know why my fuel gauge reads the amount of fuel correctly but shows on the wrong spot on the gauge? A full tank now reads at half and empty reads at about the 9 o'clock position on the gauge, for both tanks. It had been correct for a while than out of nowhere went wacky, while I am glad it still shows my fuel level it would be nice to have it show in the right spot on the gauge. Thanks
Offline Sartobuilt
Re: Fuel gauge reads correct but in wrong spot spot on gauge
« Reply #1 on: October 06, 2012, 08:03:34 pm »
The pointer could have slipped on the peg. My Tahoe did the same thing, I filled the tank and pulled the needle and replaced it at the full mark, with the cluster powered up.
« Reply #2 on: October 06, 2012, 09:12:25 pm »
I might have to do that if I can't figure out what happened, the weird thing is if I unplug the multi plug from the tank switch that goes thru the firewall the gauge goes to full, don't know why but thats what it does.
« Reply #3 on: October 06, 2012, 09:32:52 pm »
With it unhooked it should go to about 3 o'clock
« Reply #4 on: October 06, 2012, 10:30:51 pm »
Good to know, that's about how much its off too, might just have to pop the needle off and move it, thanks for the tips.
« Reply #5 on: October 12, 2012, 09:57:19 am »
They do this if the sending wire has been shorted.
« Reply #6 on: October 13, 2012, 10:28:44 am »
Interesting, maybe I will run a new wire first before messing with the gauge itself, thanks.
« Reply #7 on: October 15, 2012, 12:39:00 pm »
The shorting effects the sending unit, not the wire.
