Author Topic: another round of what are these wires?  (Read 31055 times)
Re: another round of what are these wires?
« Reply #15 on: November 02, 2012, 08:46:17 pm »
got one more that ive got no clue on. It's orange and comes out of the wiring harness directly below where the throttle cable passes through the firewall....
Kmanrsss, have you puzzled this out yet?
That orange wire might be used for the kickdown circuit on a TH400 transmission.  If it is, it should pass through the firewall to a 2- or 3-wire connector inside the cab that either plugs onto a slide switch that is operated by the accelerator pedal bellcrank, or to a relay.
« Last Edit: November 02, 2012, 09:08:46 pm by bd »
Offline kmanrsss
« Reply #16 on: November 02, 2012, 08:48:26 pm »
Sorry I haven't gotten any more pics recently. I work for the local utility and have been working 17hr days since Tuesday. I'll get some pics tomorrow.
Offline kmanrsss
« Reply #17 on: November 09, 2012, 04:17:05 pm »
here we go. Any ideas? thanks
« Reply #18 on: November 15, 2012, 06:49:28 pm »
The one coiled up looks like the proportioning valve or the oil pressure...  Which harness connector does it go to?
Offline 87454westernhauler
« Reply #19 on: November 15, 2012, 09:42:26 pm »
could that wire be for a factory tach?
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #20 on: November 16, 2012, 08:53:09 am »
i'm with capt it looks alot brake proportion valve wire. I would locate brake proportion valve ( on cross member between frame rails) and trace it back
Offline kmanrsss
« Reply #21 on: November 20, 2012, 05:23:13 pm »
I also thought brake prop. Valve, but I've got a wire connected there already. Doesn't mean it's correct. Hopefully I'll have some time this weekend to finally look into it.
« Reply #22 on: November 20, 2012, 06:27:25 pm »
The 87 brake combination valve is tan/white stripe....
Offline kmanrsss
« Reply #23 on: November 21, 2012, 04:16:08 pm »
Just checked and I have a tan/white wire at the prop valve. This wire isn't labeled so it was most likely disconnected before I started.
« Reply #24 on: December 03, 2012, 10:05:50 pm »
Could be the oil sensor, there is 2 on a 87.
Offline kmanrsss
« Reply #25 on: January 08, 2013, 03:33:36 pm »
I think I figured it out. While under the truck last night pondering the best way to remove my Transmission I found a bare connector on the DS of the Trany. Looks like it was for the kick down actuation. I guess I'm a dummy. I was positive I checked everything on that transmission. O well one less connection to lift while removing it.
