Author Topic: another round of what are these wires?  (Read 31054 times)
Offline kmanrsss
« on: October 09, 2012, 08:58:57 am »
When i removed my 87 cab i labeled all the wires i disconnected. There were some that were already broken and or disconnected. Ive got 3 wires that run in the harness that goes behind the engine, and they come out of the harness with the fat red and little purple wire for the starter.  The colors in question are a dark blue wire, black with white stripe and a tan wire.  the other wires in question are a pink with black stripe and a brown wire that go to a 2 prong plug. the plug is the same style as used on the fuel pumps. it comes out of the harness at with the red, blue, green, and yellow wire that goes into the tbi unit. i don't see any open plugs around, but was wondering if it possibly went to the air pump which is no longer there. Ive looked at the schematics and am either missing them or there not there. I am probably missing them. thanks for the help.
Offline kmanrsss
Re: another round of what are these wires?
« Reply #1 on: October 09, 2012, 10:56:24 am »
The black/whit stripe wire is spliced with 5 wires coming in, one coming out. Possible ground?
« Reply #2 on: October 09, 2012, 11:54:19 am »
Here is a partial answer:  (1) the blue wire at the starter probably connected to a knock sensor that screwed into the block water jacket in front of the starter; (2) the pink w/ black stripe is ignition, paired with the brown wire exiting the harness along with the injector wires probably connect to the 'missing' Air Management Valve and air pump; (3) w/o more info (maybe a pic), the black w/ white stripe is probably ground and may be paired with the tan wire (O2 sensor ground) to the back of the right cylinder head.
« Last Edit: October 09, 2012, 12:51:27 pm by bd »
Offline kmanrsss
« Reply #3 on: October 09, 2012, 02:16:52 pm »
Black with white appears to be grounds. The tan wire rings out to the ECM and from what I can tell is also a ground. The dark blue wire comes off the electronic spark controller. It's the port closest the engine. My colors don't match the book at all. It looks like it goes to the knock sensor. I forgot that was there. Thanks
Offline kmanrsss
« Reply #4 on: October 21, 2012, 05:21:37 pm »
got one more that ive got no clue on. It's orange and comes out of the wiring harness directly below where the throttle cable passes through the firewall. ive already got a wire on the oil pressure that is in the same harness as the O2 sensor, and the truck runs. thanks for the help
« Last Edit: October 22, 2012, 03:34:58 pm by kmanrsss »
« Reply #5 on: October 22, 2012, 03:36:49 pm »
Do you have an oil pressure gauge or light?
Offline kmanrsss
« Reply #6 on: October 22, 2012, 08:30:28 pm »
Yes there is an oil pressure gauge.
« Reply #7 on: October 22, 2012, 09:09:21 pm »
I have 3 uncut 87 TBI harnesses.  Post a pic of your harness for reference and then of the wires in question.
This is mine after I unbolted everything:
Offline 87454westernhauler
« Reply #8 on: October 23, 2012, 10:29:30 pm »
on my 87 i had i also had he same wire also not hooked up to anything at all. thought it was an extra wire that could have been for the oil light if it would of had dumy gages but it always bugged me.
79 gmc c20 350 th350
78 k1500 4x4 350 th350
« Reply #9 on: October 23, 2012, 11:41:42 pm »
The wire color in the image you posted appears more 'tan' than 'orange' and probably connected to the oil pressure sender for the 'dash gauge.'
Offline kmanrsss
« Reply #10 on: October 24, 2012, 10:20:09 am »
Bad picture of the wire itself but its orange once you trace it back to a clean spot. It's possible that it was never used as there is no label on it. Gonna dig a little more tonight. Thanks for the help so far.
Offline rsandusky
« Reply #11 on: October 24, 2012, 10:16:13 pm »
Low pressure switch on the combination valve for the brakes maybe? look on the frame rail
Offline kmanrsss
« Reply #12 on: October 26, 2012, 10:22:28 am »
Rsandusky, that was my original thought but I've got that hooked up already.
« Reply #13 on: October 30, 2012, 10:14:22 pm »
Can you tell me which connector it comes out of at the firewall plug?  Pic of it in perspective?
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #14 on: November 01, 2012, 04:17:51 pm »
Would also be helpful if your tank has dual tanks there are provision in the wiring harness for that option.
