Author Topic: Fuel Pump Question  (Read 5994 times)
Offline rockable
  • Truckin', like the do-dah man.
Fuel Pump Question
« on: October 26, 2012, 04:24:55 pm »
I am installing a crate 350 and will use an Edelbrock carb on it, so I'm going to install an Edelbrock fuel pump as well.  I have dual tanks.
The Edelbrock pump has the traditional two connections.  The OE pump has 3 connections, the suction, the pressure plus one more.  What is this small hose for?  Pressure valve return?  Drain?  I assume I plug this one.
'86 SWB Silverado
Re: Fuel Pump Question
« Reply #1 on: October 26, 2012, 04:57:36 pm »
A 3-port SB mechanical fuel pump uses the following connections:
*  3/8" hose bibb "inlet" from the tank
*  1/4" hose bibb "return" to the tank (used on some 3/4-ton & 1-ton applications to prevent vapor lock issues by moving a continuous flow of fuel through the supply line and pump to cool them)
*  3/8" steel tubing "outlet" to the carb
Offline rockable
« Reply #2 on: October 26, 2012, 06:00:39 pm »
Thanks.  I will just plug that one.
'86 SWB Silverado
Offline gildardo01
« Reply #3 on: October 26, 2012, 06:12:31 pm »
but won´t it damage the pump by building too much pressure or something? or is it ok if you plug it up?
« Reply #4 on: October 26, 2012, 07:13:01 pm »
Plugging the return pipe to the fuel tank is the sensible thing to do when converting to a 2-port fuel pump.  The only drawback in converting from a 3-port to a 2-port pump is the potential for vapor lock on hot days.
Offline rockable
« Reply #5 on: October 26, 2012, 08:43:52 pm »
I don't want to have to have a fuel pressure regulator.  I don't have a problem with my 54 Chevy.  It has a 350 SBC and Edelbrock pump.
'86 SWB Silverado
« Reply #6 on: October 26, 2012, 08:53:24 pm »
I think you will be fine with what you have in mind.
