Author Topic: Tires for Stock Rally Wheel  (Read 17849 times)
Offline ReactionDT
« on: October 30, 2012, 12:33:07 am »
I have a question about tire fitment on my 1986 C10 Silverado SWB, 2WD. The truck currently has some aftermarket bullet hole wheels that the previous owner installed that look like absolute heck. The tires currently on the truck are 235/60/15. I have the stock wheels which I have refinished and repainted. Will 275/60/15 tires go on this truck with the stock ride height and the factory 8" rally wheels without sticking out from the fenders? I want something that's going to be wide but not throwing everything off the road straight up the side of some fresh black paint. -_-
Offline DrDaryl
Re: Tires for Stock Rally Wheel
« Reply #1 on: October 30, 2012, 11:02:50 am »
I think 275/60/15's look good on these trucks.  I don't happen to have a photo; a search might turn up a photo.
Offline mattgood
« Reply #2 on: December 09, 2012, 10:37:48 am »
275s should fit and not stick out past the wheel wells. I just put 295/50/r15 tires on the rear of my 83 c10 on a 15x8 steel wheel and they still tuck in ok. Not sure if the front tires would rub when steering though. I will try and post a pic for you.
Don't let your water melon.
Offline kalbert
« Reply #3 on: January 24, 2013, 10:43:15 am »
A stock height truck with 15x8 rally wheels looks good with 255/70R15. Aftermarket wheels I like 275/60's. Check out the two trucks in this thread for an idea of what it looks like:
http://67-72chevytrucks.com/vboard/showthread.php?t=301328
The 255's are more ballony looking, but suit the truck look well especially with factory stance and wheels. 275's are just a bit wider and shorter and make a truck with a 2-2/4 drop and aftermarket wheels look more sporty.
Offline gharris79
  • Chevy Freak
« Reply #4 on: February 27, 2013, 07:59:37 am »
I have run 275/60/15's on my 87 for the last 8 years without issues.
« Last Edit: February 27, 2013, 08:08:16 am by gharris79 »
87 Chevy Silverado 2wd, 1990 Blazer, 2017 Honda Accord
« Reply #5 on: February 27, 2013, 12:28:47 pm »
You can get away with that size up to about 3" drop in the front, 4" will rub.
