Author Topic: 83 k10 radiator(bigger equivelant?)  (Read 9466 times)
Offline hoyle83
« on: November 01, 2012, 10:35:48 am »
Hey Guys,
I'm currently rebuilding my 83 silverado k10 4x4 with a brand new drivetrain complimented with a 350/290 crate and after having the rad out i was suprised to see how thin the thing is! I was curious on anyones thoughts to have a beefier rad in there...I removed the A/C so the AC rad was taken out...figured a bigger rad would be better if there was something that could bolt right up with minor modifications...Also on that same note, what is everyones thoughts on fans for this motor? stock with stock shroud? any need for a flex fan?
Thanks in advance,
Mitch Hoyle
Bridgenorth, Ontario, Canada
Mitch Hoyle
KCCO
"Work Hard To Play Hard....Or To Fix Your Toys....And Then Play Hard!"
Offline Edahall
Re: 83 k10 radiator(bigger equivelant?)
« Reply #1 on: November 01, 2012, 12:48:14 pm »
Yes, a radiator made for your truck having the 6.2L diesel option.  They had 4 core radiators rather than the 2 core radiator that's in your truck
PRO Part # 8010607
http://www.rockauto.com/catalog/moreinfo.php?pk=3606795&cc=1299326
It'll set you back about $500 but it's worth every penny if you plan on keeping the truck for a long time.  I've got this radiator and the coolant temperature stays constant even while pulling 10,000 lbs up a long mountain pass.
« Last Edit: November 01, 2012, 05:12:09 pm by Edahall »
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline westsidek20
« Reply #2 on: November 01, 2012, 03:38:27 pm »
Well I bought an all aluminum radiator with electric fans for under 300 from Champion a company in LA and I haven't had any issues, you have to buy a relay for it do.
« Reply #3 on: November 02, 2012, 07:48:49 am »
I run a stock replacement aluminum radiator for a big block in Yellow Snow. With the plow up going down the road it never goes over 190. December, January, and February I have to put a piece of cardboard in front of about half the radiator or it won't get warm enough to keep good heat in the cab. I am running a stock style fan shroud from a mid 70s Chevy truck. My fan is an 8 blade clutch style from a 1975 Plymouth Fury. I had to enlarge the mounting holes a slight bit to fit over the Chevy fan stud bolt pattern, and I had to trim about an inch off each blade to make it clear the shroud.
Offline hoyle83
« Reply #4 on: November 02, 2012, 08:52:11 am »
Thanks very much for the quick replies guys...I appreciate it! I have a line now on a big block 4 core out of a mid 80's chevy truck so i'm going to look/measure it today...Hoping it will work but it doesnt come with the red mounting brackets for the top which is a bit of a kicker but i'm sure i will find/be able to make something up anyways...
Mitch Hoyle
KCCO
Offline Edahall
« Reply #5 on: November 02, 2012, 09:32:11 am »
Just make sure it's not all corroded.  This is one item that has a limited lifespan.
-3.73 gears
-2" Lift
« Reply #6 on: November 02, 2012, 11:05:01 pm »
I made my own top brackets.
Offline hoyle83
« Reply #7 on: November 13, 2012, 09:30:08 am »
10-4, sticking with the stock rad as it's in great condition, in and out and i will upgrade as the coin comes in. Cheers
Mitch Hoyle
KCCO
