Author Topic: **need help** took vent apart can't remember how it goes back together  (Read 8225 times)
Offline pholliday1
  • 1990 V3500 Crew Cab
Have 1990 burb interior took apart passenger side vent with vacuum control.There is  a cover that protects the vacuum control. My problem is that  I need a picture of how the vacuum motor is indexed its connected to a little rod and i've tried different positions can't seem to get it right need a picture to follow please help! In my defense I took it apart about 8 years ago and when i dragged it out of the box i couldn't get it to fit.
Re: **need help** took vent apart can't remember how it goes back together
« Reply #1 on: November 15, 2012, 07:36:28 pm »
Did you figure this out?
Offline pholliday1
« Reply #2 on: November 16, 2012, 08:49:23 am »
mounted kick panel to plug hole ,its getting cold out.... only putting two screws in till i get to bone yard to make sure it put together right.
« Reply #3 on: November 16, 2012, 01:24:58 pm »
send me an email to remind me and I can get a picture of mine posted.
Your talking about the one on the right in this picture correct?
Offline pholliday1
« Reply #4 on: November 19, 2012, 09:28:26 am »
yes its the one on the right. There is some sort of decoration/protector cover over vaccum motor on a short rod that runs from motor to vent door. I guess in the big picture how often do you have the vent  open? Probably you either have heat or air on i guess. It would be nice just to get it right thought.
« Reply #5 on: November 21, 2012, 10:40:12 am »
Here are the pictures of the Vent.  Let me know if you need anything else.  The AC pulls the vent open/close.  On MAX it is closed to recirculate the air already in the cab.
Offline pholliday1
« Reply #6 on: November 21, 2012, 11:53:36 am »
Thanks Capt! Do you recall there being a return spring on this? I see the empty hole i thought i remembered a return spring.
« Reply #7 on: November 21, 2012, 01:15:21 pm »
Let me look at mine that is still hooked up, I don't think there was a spring, but....
