Author Topic: ac vacuum source please  (Read 13077 times)
Offline Low82C10
« on: November 04, 2012, 04:03:11 pm »
i did not know that in order to switch the ac selector around you had to have a vacuum source. well i have a 82 swb i just got done putting a 5.3 and put the heater hoses on and my heater works but only blows on the floor and since i didnt have that little radiator deal in the box on the firewall heat was coming out of there also. so my question is, where do i get a my vacuum source from and where does it go to? i did a search for a diagram for the vacuum for my year but came up with nothing.
Offline DnStClr
Re: ac vacuum source please
« Reply #1 on: November 05, 2012, 07:33:20 pm »
Here's a diagram for the vacuum lines, the source is going to come from the intake manifold ( constant vacuum) and then go to the heater/vac control, but the source from the 5..3L might be different.
Don
87 Chevy Silverado
Offline Low82C10
« Reply #2 on: November 08, 2012, 05:42:58 pm »
thanks helps out a lot, my question is wouldnt the source go to the vacuum reservoir? my vacuum reservoir has to outlets one which goes inside the cab.
Offline DnStClr
« Reply #3 on: November 08, 2012, 08:40:21 pm »
Sorry. You're right- it goes to the vacuum reservoir that looks like a ball. The diagram doesn't do a good job of showing it does it?
Don
87 Chevy Silverado
Offline sonicbluezx3
« Reply #4 on: November 18, 2012, 08:16:57 pm »
How about for a diesel? Would I need to just hook up to the vacuum pump on the back of the engine?
1986 Chevy K10 w/ 1983 Cab, 1984 Bed, 1987 Doors and a 6.2 Diesel Swap w/ 700R4 Trans. Truck body completely re-done between 2010 and 2012.
Offline DnStClr
« Reply #5 on: November 21, 2012, 01:53:40 pm »
Yes. On the vac pump, since there is no vacuum supply created by the diesel engine.
Don
87 Chevy Silverado
« Reply #6 on: November 22, 2012, 09:48:56 am »
Okay that's what I thought. Is there supposed to be a reducer of some sort? The outlet of the vacuum pump is a lot larger than those individual vacuum lines running into the cab.
Offline DnStClr
« Reply #7 on: November 22, 2012, 08:26:52 pm »
yeah, I don't know exactly what the fitting looks like, but here's a link for some examples
http://www.plews-edelmann.com/plastic-and-soft-rubber-fittings/
Don
87 Chevy Silverado
