Author Topic: Help please Back up light switch  (Read 26029 times)
Offline Kenan
« on: November 12, 2012, 04:35:47 pm »
Hi,
I have a1980 custom deluxe with 3 speed manual transmission and L6 engine. I need to know where the back up light switch
Is because i miss it on my truck. The ex owner may uninstall it. I have searched the internet but there are various
Types. Some say its in the gearbox and some on the steering column. It will be great if you have a picture or even
the part number for the 3 speed manual.  I hope you help me. Thank you ver much.
Kenan
This Trucks are made for driving,
And that's just what they'll do..!
Offline 84burb
Re: Help please Back up light switch
« Reply #1 on: November 12, 2012, 05:27:28 pm »
Based on the picture in my catalog it looks like it mounts to the steering column.
Hope this helps
« Last Edit: November 12, 2012, 05:35:41 pm by bd »
I just realized, I've become one of those Ol' Geezers I didn't need to listen to when I was young.
Use what you can and leave the rest as your mileage may vary.
84 - Suburban Silverado package 1/2 ton - 2wd 5.7 - 4sp AOD
77 - C10 Stepside Parts Truck
Offline Kenan
« Reply #2 on: November 13, 2012, 11:06:09 am »
Thank you but there is a difference between manuel 3 speed , mAnuel 4 speed and a/t . I think the 3 speed is in the transmission and not at the sttering column
Offline 84burb
« Reply #3 on: November 13, 2012, 12:23:39 pm »
I don't have a picture but, according to my Repair Manual the backup light switch for a three speed trans is mounted on the steering column.
I'm not sure but try looking under the hood where the shift levers are on the column.
« Last Edit: November 13, 2012, 12:26:03 pm by 84burb »
Offline Kenan
« Reply #4 on: November 13, 2012, 01:05:51 pm »
Does it look like this
Offline Kenan
« Reply #5 on: November 13, 2012, 03:17:01 pm »
Hi,
Is there no one else who can help me.
Offline 84burb
« Reply #6 on: November 13, 2012, 03:21:11 pm »
Looks like you've got a winner.
Offline 84burb
« Reply #7 on: November 13, 2012, 03:30:36 pm »
There is an adjustment when you mount it on the column so it is only on when in reverse. I'll see if my repair manual has a wiring diagram for a 3 speed BU sw for you. Power would normally come from the switched side of the fuse panel but I don't know what colors the wires would be.
Edit to add: wire colors are Dark Blue coming from the fuse block and Light Green to the lights.
Hope this helps.
« Last Edit: November 13, 2012, 03:35:14 pm by 84burb »
Offline blazing816
« Reply #8 on: November 13, 2012, 03:48:33 pm »
the one pictured is correct...the manual 4spd is the one that goes the trans I believe.
Offline Kenan
« Reply #9 on: November 14, 2012, 01:30:08 pm »
Thank you for your answers. This part is missing on my truck. I have cheked several sites like rockuto but ı couldnt fin it can you give me an advise where i can find it .
« Reply #10 on: November 14, 2012, 01:38:49 pm »
I should have one to sell, let me make sure it works first
Offline 84burb
« Reply #11 on: November 14, 2012, 03:16:13 pm »
I see you are in Turkey. Is the truck there also?
I am assuming this is a column shift and not a floor shifter.
If zieg's switch doesn't work, there is a site that claims to carry them (they are not cheap)
Have you considered simply adding a manual switch like a toggle or rocker. (it would probably be cheaper than the original) Then use it to turn your BU lights on and off. I would suggest a lighted one so you are reminded when you have them on. That way you won't blind traffic behind you as you go down the road.
Edit for spelling
« Last Edit: November 14, 2012, 04:41:41 pm by Captkaos »
« Reply #12 on: November 14, 2012, 04:42:25 pm »
Offline Kenan
« Reply #13 on: November 15, 2012, 11:42:38 am »
Thanks all of you  . Today i found one in the junkyard. Its a big suprise for me than these trucks are rare here. Its a little bit damaged but i think i can fix it . If not i will ask you again. By theway the truck is here in Turkey . Im working for longer than 4 years on it . Here some pics. Before and after .
Offline Kenan
« Reply #14 on: November 15, 2012, 11:45:25 am »
Some more pics
