Author Topic: removing rear driveshaft/yoke from carrier bearing  (Read 13336 times)
Offline bake315
« on: November 15, 2012, 12:26:14 pm »
Hey guys,
I have my driveshafts out of my '73, and am now trying to remove the rear yoke from the carrier bearing.  It looks like it should just slide out, but it only goes a couple inches, then hangs.  Tried a little friendly persuasion with a rawhide mallet, to no avail.  Is there a trick to this, or do I just need a larger hammer?
Thanks!
bake315
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
Offline bake315
Re: removing rear driveshaft/yoke from carrier bearing
« Reply #1 on: November 17, 2012, 08:08:54 pm »
Nobody knows?
Offline gildardo01
« Reply #2 on: November 17, 2012, 08:15:53 pm »
there is no trick... i think maybe some wd 40 and some persuasion might do the trick... has to, because its supposed to slide in and then it just tightens up with the nut... there is no science in it...  you are talking about the pinion yoke right...
Offline bake315
« Reply #3 on: November 17, 2012, 09:35:00 pm »
No, not the pinion yoke - this would be at the other end.  Here's a couple of pictures...
Offline gildardo01
« Reply #4 on: November 17, 2012, 09:54:15 pm »
oh gotcha... didn´t think about the carrier bearing, since my chevy doesn´t have one. and i dont have experience with them so we´ll see if someone else will chime on this...
« Reply #5 on: November 18, 2012, 01:27:42 am »
You have to losen the nut on the end of the female side of the slip joint. Once that is off it will slide right off.
Offline thirsty
    • Suitor's Garage
« Reply #6 on: November 18, 2012, 08:07:41 am »
X2
Just like a front driveshaft.
« Reply #7 on: November 18, 2012, 08:42:11 am »
this
Offline bake315
« Reply #8 on: November 18, 2012, 02:10:46 pm »
this
That's a nut?  I had no idea!  Thanks!
« Reply #9 on: November 18, 2012, 09:36:33 pm »
I would call it a nut! I am not sure what its real name is, but it threads on.
Offline bake315
« Reply #10 on: November 19, 2012, 02:29:18 pm »
 Yeah, once I got it cleaned up enough to actually see the threads, it was sorta obvious.  ::)
