Author Topic: Engine Rebuild Choices - 383  (Read 4079 times)
Offline bladerunner
« on: November 16, 2012, 09:45:28 am »
The 350 in my truck is currently leaking oil like a sieve so i have been exploring rebuild options. I want to do some performance modifications as well to make the effort worthwhile.  I have never done a rebuild, but I have pulled engines and replaced gaskets, oil pumps, etc so I think I can handle it. I am leaning towards stroking the engine and wanted some recommendations on parts. I am looking at a 383 build in a Dave Vizard book I own as my basis:
Crank: Scat 3.75 9000 cast steel
Rods: Scat stroker rods
Pistons: KB cast flat top .030 oversize
Cam: COMP Xtreme Energy 270
Lifters: COMP 812-16 hydraulic flat tappet
Valvetrain: COMP 986 springs, alum. roller rockers 1.6 intake and exhaust
Heads: Fully ported 186 iron w/ 2.02/16 valves
Intake: Edelbrock Performer RPM 2-plane
Carb: Holley 750
Headers: walker 1 5/8 inch
Block will be bored.030 over and decked to 9.000 inches
Resulting CR is 10:1
My big questions is what else can I do for heads? The heads mentioned I have been told are not that common and I am better off going with something new/aftermarket. Perhaps Dart 180cc or something?
Thoughts on this setup?
« Last Edit: November 16, 2012, 12:27:55 pm by bladerunner »
85 K10 Shortbed
94 Impala SS
Re: Engine Rebuild Choices - 383
« Reply #1 on: November 16, 2012, 01:20:21 pm »
What is the intended purpose?  I wouldn't run any pre-96 head on it, I would go Vortec heads if cost is an issue and change the intake to match.
Offline bladerunner
« Reply #2 on: November 16, 2012, 01:40:59 pm »
I don't really have a serious answer to that, but I want more power, specifically more low end torque. So just for kicks.
I figured you would say Vortec. Whats a fair price on used Vortec heads? Any recommendations for aftermarket Vortec heads?
85 K10 Shortbed
94 Impala SS
