Author Topic: Body Panel required to replace part of seat hump?  (Read 3969 times)
Offline project1
« on: November 16, 2012, 08:49:08 pm »
Another question about my 86 chevy already purchased outer rocker panels and cab corners, but wanted to know what the name of the piece or if there is one availble for replacing part way up the outer seat hump (rocker panel side) looked around at different sites for panels but not sure what to order, would the inner rocker panel cover some of the seat hump? Tried uploading a pic but the file size was to large if a pic is needed I will try a little harder!
Offline hotrod24
Re: Body Panel required to replace part of seat hump?
« Reply #1 on: November 16, 2012, 09:39:03 pm »
1978 pontiac grand prix...
Offline thirsty
    • Suitor's Garage
« Reply #2 on: November 17, 2012, 05:01:53 am »
If the pieces that hotrod24 linked to aren't big enough you will have to use flat stock.
Offline project1
« Reply #3 on: November 17, 2012, 04:49:48 pm »
Finally got a pic loaded
Offline hotrod24
