Author Topic: RPO Codes  (Read 36190 times)
Offline blazing816
RPO Codes
« on: November 19, 2012, 10:29:58 am »
Hey all, I am looking to start my frame up restro and I have all the originall RPO codes from the glovebox and I want to make the truck as original as it was before (other then motor). BUt I had some things I could not find and some things did not understand. Also the body was scrapped before I got the frame and glovebox so I know nothing. Anyway here are my questions:
1. I didn't find the paint code??
2. What is the trim package?? (aka Scottsdale, custom deluxe??)
2. What is B3W??
3. What is K19: Reactor System Air Injection??
4. What is Z88: Conversion, Name Plt GMC??
5. What is E6C: Country Gambia??
6. What is TFE: SALES INCENTIVE COMMITMENT PLUS??
7. What is YH7??
Thanks for the help to all.
Offline CoggedBelt75
    • Truck Album
Re: RPO Codes
« Reply #1 on: November 19, 2012, 10:36:01 pm »
Here is an attempt
I don't see it on the sticker either. Here's what you should see...http://www.automotivetouchup.com/paint-codes/chevrolet.htm
2. What is B3W??
Smog pump and plumbing..an example http://www.autozone.com/autozone/repairguides/Chevrolet-Nova-ChevyII-1962-1979/Emission-Controls/Air-Injection-Reactor-System/_/P-0900c15280081fe8
7. What is YH7??
BONUS VALUE OPTION PACKAGE....It means it was a year end close deal and they packaged a bunch of options together as a bonus to move the truck.
Joe
1975 C10 blown 383
Offline blazing816
Re: RPO Codes
« Reply #2 on: November 20, 2012, 08:17:07 am »
well thanks for the few you could add. The paint one is the one bumming me out the most. But I guess if I do not know the original color, it leaves it up to me to pick.
    • Truck Album
Re: RPO Codes
« Reply #3 on: November 20, 2012, 09:16:10 am »
If you feel like the paint on it now is the original paint and have a local Oreillys they may be able to help. Ours has a paint dept. and the guy that manages it has a scanner he can run across the paint and it will give out all the info on what needs to be mixed with what to match it. Just  a thought.
Joe
1975 C10 blown 383
Offline blazing816
Re: RPO Codes
« Reply #4 on: November 20, 2012, 01:29:15 pm »
That would work if I had the body....the body was scrapped before I bought it because it was "too rusty" So I only have the frame and the glovebox. But the glovebox is a gunmetal greay type color so maybe ill take the glovebox down to o'reilys. Thanks
Offline Cali-Deuce
  • Old School Hot Rodder and heck Raiser
Re: RPO Codes
« Reply #5 on: November 21, 2012, 12:51:35 pm »
I did some RPO code look ups and found this information based on the label pic shown.
A52 : SEAT, FRT BENCH
B3W: Not listed in my info
B7N : BODY EQUIPMENT, PICKUP BOX PANELS (NON-PRIME)
CMD : PLANT CODE, FLINT MI (where truck rolled off the line)
C5M : GVW RATING, 6100 LBS
C91 : LAMP, INTR, ROOF, COURTESY
D1G : GEAR, SPEEDO DRIVEN
D45 : MIRROR O/S, SST
E5Z : SPEEDOMETER ADAPTER (DELETE)
E6C: Not listed in my info
E83: Not listed in my info
E9Z : SPEEDOMETER KEY (DELETE)
GQ1 : AXLE, STD RATIO
GU4 : AXLE REAR, 3.08 RATIO
JB5 : BRAKE, POWER, DISC/DRUM, 6400 LBS
K19 : REACTOR SYSTEM, AIR INJECTION
K81 : GENERATOR, 66 AMP
L03 : 5.0 LITER V-8 TBI ENGINE
L03 : ENGINE, GAS, 8 CYL 5.0L TBI
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
MX0 : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NY7 : SHIELD, TRANSFER CASE
N41 : STEERING, POWER, VARIABLE RATIO
SLM : STOCK ORDER, PROCESSING CODE
TFE: Not listed in my info
UA1 : BATTERY, HEAVY DUTY
U37 : LIGHTER CIGARETTE
V01 : RADIATOR, HEAVY DUTY, VAR I
V43 : BUMPER – PAINTED, REAR STEP – WITH STEP PAD
V73 : ANTENNA, FIXED
V73 : VEHICLE STATEMENT, USA/CANADA
V76 : FRONT TOWING HOOK
XFL: Not listed in my info
X6Z : HUB, LOCKING AUTOMATIC
YD3 : FRONT AXLE, BASE EQUIPMENT FOR SCHEDULING, GVW PLATE
YD5: Not listed in my info
YD6 : REAR SPRING, BASE EQUIPMENT
YFL: Not listed in my info
YH7: Not listed in my info
ZFL: Not listed in my info
ZY1 : COLOR COMBINATION, SOLID
Z53 : CLUSTER, INST, OIL, COOL, TEMP, VOLTS
Z75 : CONVERSION NAME PLATE CADILLAC
Z88 : CONVERSION, NAME PLT GMC
23C : TRIM COMBINATION, CLOTH, BLUE (C)
23I : INTERIOR TRIM, LT BLUE (91)
90U : PRIMARY COLOR, EXTERIOR, GRAY MET (91)
Deuce
Re: RPO Codes
« Reply #6 on: November 21, 2012, 01:10:52 pm »
1GTEV14H5HF714714
1= United States
GT= G.M.C.
E= 6001-7000 Hydraulic
V= 4 Wheel Drive 1987-1991
1= 1/2 Ton
4= two door cab
H=305 V8
5=Check Digit
H= 1987
F= Flint Plant
714714=Production Number
Trim codes for a 1987 is:
Base model - GMC Sierra
Z62 - GMC High Sierra
YE9 - GMC Sierra Classic
A52 - SEAT ASM,FRT BENCH
B3W - TIRE ALL P205/50R 15/N BL RIPE ST TL KW4
B7N - BODY EQUIPMENT,PICKUP BOX PANELS(NON-PRIME)
B7N - FLEET INCENTIVE THE PREMCOR REFINING GROUP (N/U/W-TRK CKST)
CMD - ASSEMBLY PLANT - FLINT, MICHIGAN
C5M - GVW RATING, 6100 LBS
C91 - LAMP INTR, ROOF, COURTESY
D1G - GEAR, SPEEDO DRIVEN
D45 - MIRROR,O/S BELOW EYELINE(STNLS STL)
E5Z - SPEEDOMETER ADAPTER (DELETE)
E6C - COUNTRY GAMBIA
E83 - WHEEL BASE MODIFICATION
E9Z - SPEEDOMETER KEY (DELETE)
GQ1 - REAR AXLE - STANDARD
GU4 - AXLE,RR 3.08 RATIO
JB5 - BRAKE SYSTEM,VAC PWR DISC/DRUM
K19 - AIR INJECTION SYSTEM
K81 - GENERATOR,66 AMP
L03 - V8 5.0 Lier (305 CI EFI)
MD8 - TRANSMISSION,4-SPD AUTO (THM700R4)
MX0 - MERCHANDISED TRANS AUTO PROVISIONS, O/D
NA5 - EMISSION SYSTEM,FED REQUIREMENTS
NY7 - SHIELD,TRFER CASE
N41 - STEERING,HYD(VARIABLE RATIO)
SLM - STOCK ORDER, PROCESSING CODE
TFE - SALES INCENTIVE COMMITMENT PLUS
UA1 - BATTERY,H.D.
U37 - LIGHTER CIGARETTE
V01 - RADIATOR HEAVY DUTY, VAR 1
V43 - BUMPER RR STEP, COLOR
V73 - ANTENNA, FIXED
V73 - VEHICLE STATEMENT USA/CANADA
V76 - HOOK TOW
XFL - TIRE FRONT P235/75R15-105S BW R/PE ST TL ALS
X6Z - HUB LOCKING AUTOMATIC
YD3 - AXLE (BASE EQUIP) FOR SCHEDULING GVW PLATE
YD5 - SPRING FRONT BASE EQUIPMENT
YD6 - SPRING RR, BASE EQUIPMENT
YFL - TIRE REAR P235/75R15-105S BW R/PE ST TL ALS
YH7 - BONUS VALUE OPTION PACKAGE
ZFL - TIRE SPARE P235/75R15-105S BW R/PE ST TL ALS
ZY1 - Solid Paint Color
Z53 - GAGE.VOLTMETER,OIL PRESS & TEMP
Z75 - SHOCKS,FRT QUAD
Z88 - CONVERSION,GMC
23C - TRIM COMBINATION, CLOTH, BLUE (C)
23I - INTERIOR TRIM, LT BLUE (91)
9OU - PRIMARY COLOR, EXTERIOR, GRAY MET (91)
Quote
Grey Metalic (90U) and blue Cloth (23C/23I) interior
Quote
Base as no option is listed
Quote
2. What is B3W??
P205/50R/15 tires
Quote
Yes, AIR INJECTION SYSTEM
Quote
Means it is slated to be a GMC Not a Chevrolet
Quote
That is correct, but NO Idea why.
Quote
It was a year end special sales truck, see next answer
Quote
7. What is YH7??
Offline DnStClr
Re: RPO Codes
« Reply #7 on: November 21, 2012, 01:26:07 pm »
Ha! Ya beat me to it Chris! I was just going to get the same info on the vin. So I'll just give the website for ALL the rounded line VINs. There,  ( well, all except the 73 models...)
http://www.vehicleidentificationnumber.com/vin-decoder/gmc-general-motors-truck.html
Don
87 Chevy Silverado
Re: RPO Codes
« Reply #8 on: November 21, 2012, 01:58:17 pm »
There is a VIN Decoder on the main site here for all of our trucks.  (being updates as needed)  Found an old version the other day...
http://www.73-87chevytrucks.com/VIN.htm
Offline 77 Scottsdale
Re: RPO Codes
« Reply #9 on: May 03, 2018, 09:59:19 am »
I know this thread is a little old, but I have some codes that I can't find either. ZLB, XLB, YLB. I know 53L is Colonial Yellow paint but I didn't see it in the RPO codes thread. I wonder if that is a common color or not   ???
