Author Topic: FRONT GRILL AND HEADLAMP ASSY.  (Read 4923 times)
Offline PURESTREET5006
« on: December 29, 2003, 08:54:00 pm »
I have a 87 chevy suburban silverado" and i was wondering will the 89-91 front grill and headlamp assy will work on my truck:D   I think the 89-91 suburbans have the one piece headlamp set up.
Thanks Guys....Darrin
Edited by: PURESTREET5006 at: 2/16/04 2:07 pm
Offline problazer
90 burb nose........
« Reply #1 on: January 16, 2004, 05:27:00 pm »
Everything on you truck is the the same as a 90 burb other than the core support. There are two different burb noses a two headlight and a four headlight. The two headlight is knows as a "stripped down" nose. And the four headlight is known as the "micro light" nose. To switch over to the burb nose you need to change the core support, headlight, grill and headlight harness. The burb core support will bolt into the place of your old one it just has different "light knock outs" for the headlights to set into. Triing to do it without the core is a huge pain in the ass!! It is a project that usually takes about 3 or 4 hours to complete but talk about a MAJOR face lift!! Seriously updates the look of the truck.  Good luck.
