Author Topic: Seat belts  (Read 17569 times)
Offline Crosslybobo
Seat belts
« on: December 01, 2012, 09:56:09 pm »
Got some bucket seats yesterday from a guy at work who is parting out his 90 suburban. Will the stock seatbelts in my 82 work. I got the bench seat. Are the plug in parts going to work well with the new bucket seats? Looks like shoulder parts will be ok. If not what do I need to buy
Offline Crosslybobo
Re: Seat belts
« Reply #1 on: December 02, 2012, 07:01:10 pm »
No
Offline thirsty
    • Suitor's Garage
Re: Seat belts
« Reply #2 on: December 02, 2012, 07:11:20 pm »
What do you mean by this?
Offline Crosslybobo
Re: Seat belts
« Reply #3 on: December 02, 2012, 07:43:29 pm »
The part that you plug into that sticks up through the bench seat. Is that thing tall enough to work with buckets. Seems like you need the tall stiff piece that will always stick up
Offline thirsty
    • Suitor's Garage
Re: Seat belts
« Reply #4 on: December 02, 2012, 08:04:17 pm »
Just lug it over to your truck and try it would be the quickest answer if you already have the seats from him.
Didn't you already have some buckets that you reupholstered?
Offline Crosslybobo
Re: Seat belts
« Reply #5 on: December 02, 2012, 10:44:30 pm »
no
But i would like to get these reupholstered if it dont cost a arm and a leg. There is a big tear in the middle.
Seems like the suburban had the buckle sticking up some kind of way. Some kind of plastic sheath that made them stick up. Of course the bench seat dont have those.
« Last Edit: December 02, 2012, 10:49:23 pm by Crosslybobo »
Re: Seat belts
« Reply #6 on: December 03, 2012, 07:29:32 am »
Offline 84burb
Re: Seat belts
« Reply #7 on: December 03, 2012, 08:47:49 am »
Yes, the suburban had a plastic sheath that held the inside belt up between the seat and the console. It's not very strong and breaks easily down at the floor. When I get my seats redone, my plan is to build a slot into the side of the cushion to capture the belt.
I just realized, I've become one of those Ol' Geezers I didn't need to listen to when I was young.
Use what you can and leave the rest as your mileage may vary.
84 - Suburban Silverado package 1/2 ton - 2wd 5.7 - 4sp AOD
77 - C10 Stepside Parts Truck
Offline blazing816
Re: Seat belts
« Reply #8 on: December 03, 2012, 01:03:44 pm »
If you use the center console I have run the belts through that and all of you have to do is cut a slit in the console and it will hole the inside belt for easy access. Or us some thin gauge sheetmetal to replace the plastic sheath, just make sure you file the edge so you do not cut yourself everytime you buckle up....lol.
