Author Topic: How much lift does this truck have?  (Read 13019 times)
Offline 454Man
  • Why Race?
« on: December 05, 2012, 08:56:12 pm »
Anyone?
It has 33s
Offline clay7
  • farm boy
Re: How much lift does this truck have?
« Reply #1 on: December 05, 2012, 09:02:40 pm »
looks like maybe 2 inches to me. i have 4 and clear 35's pretty well
if you cant win,cheat. if you cant cheat,DONT PLAY!
Offline Big Katz
« Reply #2 on: December 05, 2012, 11:42:13 pm »
Looks like one of my trucks that doesn't any lift.
Offline thirsty
    • Suitor's Garage
« Reply #3 on: December 06, 2012, 08:13:20 am »
Looks stock to me. The fenders and the tires are going to get into an argument.
Offline mehunter1
« Reply #4 on: December 06, 2012, 08:43:12 am »
I agree with thirsty looks stock to me as well.  I had an 83 k20 back in high school and ran 33/12.5/16.5 on it with no rubbing.  How you ask.   Well it had heavy duty rear leaf springs so the back set higher already and then the previous owner had added some additional leaf spring pieces to the front to level it out.  Looked as though it had about a 2 inch lift, but set stock.
Offline 454Man
  • Why Race?
« Reply #5 on: December 06, 2012, 08:44:01 am »
Ok that's two for no lift. The seller states that the trick is lifted. i'm trying to duplicate the look/lift on my truck. the back of my truck is that height but the front is lower. My truck has a factory towing package (sits higher in the back). For my 2wd what are my options for lifting the front. No hard off roading, just couple of bumps to my fishing hole.
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #6 on: December 06, 2012, 10:04:29 am »
How bout 3 for none. Looks like one speed bump and the fenders will go flyin
« Reply #7 on: December 06, 2012, 10:35:29 am »
Big block 1 ton springs are going to make is sit up the highest in the front end of a 2 wheel drive truck.  http://forum.73-87chevytrucks.com/smforum/index.php/topic,25053.0.html is my one ton extended cab, sits perfectly even and with slightly larger tires would give you the look you are going for I believe
Offline 454Man
  • Why Race?
Re: Re: How much lift does this truck have?
« Reply #8 on: December 06, 2012, 10:54:00 am »
Great! So its an easy swap. figure I will do ball joints and such while i'm there swapping springs. Guess ill keep my eyes open for some 1 tons parting out
