Author Topic: 87 V10 Chevy Silverado 350 5.7L V8. Won't shut off.  (Read 3733 times)
Offline JuneBug
« on: December 09, 2012, 05:03:55 pm »
I recently acquired my mom's truck that I have been in love with for years. I am trying to fix all the issues it has and one is that it doesn't always turn off when the key is turned and pulled out. What could possibly be the problem?  The engine is new only has about 10K miles. It has a Edelbrock 650 Electric Choke,  A/T.  I recently replaced the fuel sender assembly and fuel pumps in both tanks at they were both shot. Have a leak in the tranny but I'm sure that is filter and gasket related. So I hope I have given enough info to get an answer. I'm thinking bad ignition switch but not sure.
Shelley
Offline ralphhemi
Re: 87 V10 Chevy Silverado 350 5.7L V8. Won't shut off.
« Reply #1 on: December 09, 2012, 06:36:42 pm »
Check with a test light or a voltmeter  on the positive side of the coil or the + terminal  on the distributor, and see if the power turns off when you turn the  ING . off    You could try unplugging the Ing. switch
Ralphhemi
